Novarossi engines thread
#2176
7x17x5
#2177
If you will pardon the rather basic question here. Sorry to take you guys away from what your talking about here but..............
Could you tell me what the difference is between a C8TF and a C8TGF.
I didn't notice the difference before but my Nova Rossi 12-3 CT runs on the C?TGC(F) plugs.
I want to place an order to get more plugs and it's then I noticed?!
I hope you can help me.
Thanks in advance.
British Menace
Thanks in advance.
British Menace
#2178
Guys, I would like a like help with the 35 PLUS engine.
What will be the head clearence (shim) for running the 35 PLUS on 1000mts, Cordoba Argentina with 25% Nitro?
Thanks for the help.
#2179
use 0.60mm shim..........
PLuG 7f or 8F if you face overheating problems........
you can go up to 130ºC with safety.........
During the event we used Tornado 25%, I can't say if this setting works with other fuel brand..........
I suggest to use 2015 of 2006 exhaust, the manifold is up to your driving style..........
to make 5 minutes is almost impossible with 9.0mm venturi.........you can try it but you will end up choosing 8.5 or 8.0mm........
#2180
Thanks in advance.
British Menace
Thanks in advance.
British Menace
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example: The Novarossi C8TG (F) or (C)
Product: C (Conical)
Wire Thickness: 8
Plug Type: T (Turbo)
Plated: G (Gold)
Thermal Range: F (Fredda = Cold) C (Calda = Hot)
AFM
#2181
Originally Posted by SalvadoriRacing
I was there at the PRE WC.........
Thanks for your help, a hope to meet you at the track.
#2182
I have a MT12 from 1999-2000 and it runs ok when rich, 5 mins a tank or less. When i lean it out, and give it full throttle, she bogs and cant maintain that high RPM, does this mean engine is no good anymore seeing as i cant lean it out anymore with out having it bog at full throttle?
thanks~
thanks~
#2184
Salvador how about 2018 pipe? I will race the last National Argentina race before the World. on August 17-19...
yes this pipe works amazingly........
flavio elias used this pipe there...
anyway I think the 2018 is just the EFRA number for RB, because the pipe works pretty the same as the 2015..........
I remember the old 2601 from nova/top/rex was the same as the 2604 from RB (words of Bernard Duran from RB Concept)
#2185
their is still compression in the engine, its just when i lean it out to get longer run time it like struggles at full throttle, but then once i make it a little richer, it can go full throttle without any bogging, its kind of weird
#2186
#2187
Originally Posted by MRX4-R03
Sounds like you are lean some where, I would start from the base setting and go from there, and if you don't know the base setting just open up the low end untill there is a little bog from where there is too much fuel and the bottom and start from there, and also open up the high speed alittle and start tunning from there.. Once you have the top end set "h/s" then start with the low speed needle one hour at a time. and if there is a mid needle don't mess with ip make sure it is flush..
#2188
If you lean the high speed needle richen the bottom needle.
And if you don't get 5 min runtime try other manifold or pipe or ad
shims to reduse compression.
this should help.
this should help.
#2189
Alright everyone,
Just got a Nova N12 LS5 and i'm wondering if the cooling head is interchangable with the newer plus 12-3ct head, the (shorter blue heads) or are dimensions different?
Also have i anything to look out for with this engine, easy to tune? how does it like to be run? has anyone got the factory needle settings to hand....
Thanks in advance
adam.
Thanks in advance
adam.
#2190
hello at all,
does anyone know the ball diameter from novarossi ball bearing number 16001 and 16002, this are the rear bearing from the 35plus21 engine.
thanks for fast answer
dieter
dieter
