STS engines
#1021
Re: nitro content?
Originally posted by noobatron
Hey guys,
i'm currently running 16% nitro on my D5 atm. Would it rev faster if i put the copper shim back and run 30% nitro?
Hey guys,
#1022
STS carb
Hi dino,
I was using a RB carb before and have decided to swap back to the STS carb. I havn't used the carb ever and noticed that the mid speed needle is not flush to the carb, it looks like half a turn out(.05mm) from the carb. Is this right? Should i adjust it to be flush with the carb or is this the factory setting?
Thanx
Thanx
#1023
Re: STS carb
Hi dino,
Thanx
Hi dino,
Thanx
#1024
Re: STS carb
Hi dino,
Thanx
Hi dino,
Thanx
#1025
Re: Re: STS carb
Originally posted by dino.tw
Yes,adjust it to be flash with the carb.
#1026
Re: Re: STS carb
Originally posted by 20 SMOKE
Why did you change it did you like the rb carb beter ??
any tips?
#1027
STS D21B
#1029
Parts IN!!!!!
hey all i just recieved my D3R p/s set and installed them in the D3 case, just need to break-in the engine; once i find the time. Hey does anyone remeber the stock settings for the D3(D3R)? is it 4-HSN and LSN-flush with carb body and the mid-needle flush?
But yeah I am stoked!!!!
~Jason
~Jason
#1030
Hope you have better luck with yours than I have with mine.
I can't get the engine to run properly without seeing temps in the 230(idle) - 270F(after running) range. If I go to a cooler setting it is way to rich to rev out and usually stalls after idling for 3 secs when the throttle is opened.
I've tried the factory settings (LSN 4 turns out, Mid fulsh and HSN 4 turns out) but these are too rich for the motor to rev and it idles at 230F. I have tried all manner of needle settings but it's not happening for me. I pulled the carb to pieces, replaced one damaged o ring, sealed every part of the carb I could and still it seems like it has an air leak at idle.
I didn't have this trouble with either my Force 15 or the Picco Omega XT I was running before, although these were both rotary carbs.
I bought a couple of second hand motors and these are going to have to do since this STS motor is very unfriendly. I want to race, not spend frustrating days dicking around with the settings that I can never get right.
I wouldn't even want to sell this motor to someone else as I couldn't handle selling someone a dud.
#1031
*opens arms wide wide open*
I wouldn't mine giving it a go, with the option you take it back if you want it... ?! <grin> (Yeah im in OZ)
#1032
Zoom
Try add extra head shims and run #7 plug for start, you should see the different.
#1033
Originally posted by tl2111
Zoom
Zoom
I'll throw the shims back in it and see what the deal is. I've got an RB #7 plug there so I'll see what happens.
#1034
Thanks Tommy, I'll try that, but I would have thought that increasing the combustion chamber size would have made it even richer, but it's the only thing I haven't tried. I spoke with Dino yesterday and he said using only the aluminium shim (copper shims removed) with 16% nitro and a Novarossi #5 plug should have been fine.
You still use the smaller cooler head? 9 fins one?
