incar fans
Old 12-12-2003, 07:28 PM
xray racer's Avatar
Trader Rating: 22 (100%+)
Default incar fans
hey
i was wondering how you plug in fans that you put in ur car to keep it cooler???
ive made my own out of a very small computer fan ( like 2-2.5cm square) and i can put a receiver plug on it n plug it in to whatever, but what do i put it in???
its actually a 12v fan, but it spins fast enough on 7.2v and im putting it in my xray, i just dont no wot to plug it in to
do i need a seperate power source, like a seperate receiver pack???
any help would be great
thanx
robbie lloyd
xray racer is offline
Old 12-12-2003, 08:27 PM
rc-zombies's Avatar
The fan draws very little power...
You can plug it into the BEC slot on the receiver...
rc-zombies is offline
Old 12-12-2003, 08:34 PM
xray racer's Avatar
thanx 4 that m8,
just another thing, the fan only has 2 leads, positive and negative, does the reciever bit have to have 3??
and also, r u sure bout that, i dont wanna dump in stock
and i dont wanna blow nething up
please reply asap
thanx buddy
Old 12-12-2003, 08:50 PM
alch's Avatar
Originally posted by xray racer
thanx 4 that m8,
please reply asap
thanx buddy
No it only needs the 2, the 3rd is for signal if im not mistaken..
Transponders only have 2 leads!
Alch
alch is offline
Old 12-12-2003, 08:53 PM
xray racer's Avatar
so alch, if i solder that lead to the fan n plug it in, it will work???
also, is the bec slot the 3rd slot???
i have the ko 297fz for the mars controller, n i have the speedy slot, the servo n then one more, is that it?
Old 12-12-2003, 09:04 PM
alch's Avatar
It should work yes! transponders are plugged into the BEC slot!
It should also be the 3rd slot, if its a 2 channel receiver..
Does its have anything written next to each slot? like ch1, ch2, bat.. just to make sure.
Alch
alch is offline
Old 12-12-2003, 09:06 PM
xray racer's Avatar
it says ch1, ch2, bat
is it the bat slot????
Old 12-12-2003, 09:18 PM
alch's Avatar
Yep sure is..
Alch
alch is offline
Old 12-12-2003, 10:01 PM
I bought a small radioshack fan with BEC preinstalled and put it over my GT7. I didn't notice anything different, but it sure draws some looks. My friend even went as far as to install one onto the roof of his car, and installed a real scoop. Works really good.
Gped0124 is offline
Old 12-12-2003, 10:14 PM
ottoman's Avatar
Trader Rating: 13 (100%+)
The 12 volt fans spin too slow on 7 volts... get a 5 volt fan. I wire mine to the motor... when you pull the trigger the fan spins. Since you dont have to lift much in stock it works very well.
ottoman is offline
Old 12-13-2003, 09:02 AM
TPhalen's Avatar
Here's a little sample of the twin-fan setup I use. It runs off the terminals on the ESC and provides ALOT of air. Both are small 5 volt fans that run on a separate switch. I can use them in the hot weather times or leave them off in the cold. Just a little 'extra' item I wanted...
Fan Install Pix
Be prepared, they are large pix. I haven't resized them yet for the article I'm doing....
TPhalen is offline
Old 12-13-2003, 11:23 PM
Fred Hubbard's Avatar
Tony,
Those pictures SUCK....LOL.... See ya tomorrow...
Fred Hubbard is offline
