Which brushless esc has 1s lipo cutoff? >
Old 04-24-2009, 10:10 AM
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Default Which brushless esc has 1s lipo cutoff?
just as it says, which brushless esc has 1s lipo cut off? going to run 1s in 12th scale and would like the peace of mind that it has lipo cut.
rx7ttlm is offline
Old 04-24-2009, 10:44 AM
wwoodruff
Guest
Posts: n/a
I don't think anyone has that option yet. The guys at Tekin have discussed it and would be the first I imagine though, it would only require a software update on the RS and RS pro.
Old 04-24-2009, 11:01 AM
Company Representative
Novak's 540 motor controllers (brush & brushless) run on 4 NiMH or 1 lipo. So the esc is not the issue. It's usually the servos and receivers that do not operate efficiently at such low voltage.
We offer the SmartBoost, which is both a booster circuit and a one-cell lipo cut-off module:
Novak's SmartBoost Module
NovakTwo is offline
Old 04-24-2009, 11:08 AM
wwoodruff
Guest
Posts: n/a
Thats great, but I thought he was asking who has a 1s lipo cutoff built into the ESC software. Does the Novak esc's have this feature?
Old 04-24-2009, 12:03 PM
Trader Rating: 16 (94%+)
Nobody has a 1s LiPo cut-off currently since it is not even an official ROAR class yet. The Tekin guy stated in the 1/12 Forum that they are trying to develop a software update specifically for 1s LiPo, but until then, no ESC has one.
Like the Novak guy KINDLY stated, the 1s LiPo booster will be as close as you can currently get.
kn7671 is offline
Old 04-24-2009, 12:04 PM
rx7ttlm's Avatar
cool, thanks guys. I know a RX pack is preferred for servo operation etc. was just hoping someone had an esc that could do it internally. figured tekin would be on it with the 1s but I don't run their stuff. Looks like novak module takes the win for the moment.
rx7ttlm is offline
Old 04-24-2009, 12:10 PM
CL
CL's Avatar
Trader Rating: 34 (100%+)
Losi xcelorin sensored speedo have 1S cutoff.
CL is offline
Old 04-24-2009, 12:20 PM
rocketron's Avatar
Trader Rating: 16 (100%+)
Both the Xcelorin and Castle ESC can be set to 1S cutoff. By setting the battery type to NiMH and then adjust the cutoff voltage to 3.3V or what ever you think best.
rocketron is offline
Old 04-24-2009, 12:23 PM
Yaksaddle's Avatar
Trader Rating: 33 (100%+)
Im running the 4 cell GTB SS with the 1S in 12th scale no issues whatsoever, they dont have a 1S lipo cutoff per se, but the ESC works fine with both 17.5 and 13.5 based on my usage, NO PT or Servo issues yet - I even ran it for 30 minutes straight and didnt have any issues with the electronics.
Yaksaddle is offline
Old 04-24-2009, 12:36 PM
wwoodruff
Guest
Posts: n/a
And I KINDLY replied. What gives?
Old 04-28-2009, 10:15 AM
OllieRDX's Avatar
You can set the GM speedo to 2.5v cutoff so it is possible with that speedo.
Gtrs Ollie
OllieRDX is offline
Old 04-28-2009, 12:24 PM
Trips's Avatar
But the only way you're going to get an Xcelorin mounted in a 1/12 chassis is to make a trailer for it...
Trips is offline
Old 04-28-2009, 01:36 PM
rx7ttlm's Avatar
thats what i was thinking lol
rx7ttlm is offline
Old 04-28-2009, 02:54 PM
Team Tekin
Randy_Pike's Avatar
Our 1s lipo software is being tested right now. It should be out shortly.
Randy_Pike is offline
