After run oil
Old 04-22-2009, 02:31 PM
Default After run oil
Ok guys I tried using the search bar, but it's not working right now.
Red ARO is bad for silicon filled cranks and the clear stuff is fine for silicon filled cranks right?
I remember reading that ATF could be used for ARO. Is this true?
Alan D. is offline
Old 04-22-2009, 02:33 PM
imaxx21's Avatar
get the GMK after run, its the best and comes with a syringe...
http://www.amainhobbies.com/product_...ducts_id/12719
imaxx21 is offline
Old 04-22-2009, 03:20 PM
how do you apply that, yoy put it in your fuel line and start the engine or what?
rgrassey@me.com is offline
Old 04-22-2009, 03:25 PM
imaxx21's Avatar
use a piece of fuel line to the carb, squeeze some in and turn the engine over on the starter box
i like this better than pulling out the glow plug because there is no chance of letting dirt in
imaxx21 is offline
The way I understand it is that you take off your fuel line from the carv and put inject it directly into the carb nipple.
Alan D. is offline
Old 04-22-2009, 03:26 PM
imaxx21's Avatar
nice, same time
its very good oil and is safe for all silicone ramps...
imaxx21 is offline
Old 04-22-2009, 04:32 PM
sugelle's Avatar
Trader Rating: 63 (100%+)
I have also heard some people say that the red ARO is nothing but Tranny Fluid. Not sure if that is true or not??? I don't run modded engines so I don't worry about the silicone ramp stuff and I use the red ARO religiously.
sugelle is offline
Old 04-22-2009, 05:22 PM
mista.matrix's Avatar
how bad is the red AFO, I used it one time & its sitting in my engine for about 4 days......
mista.matrix is offline
