Like Tree130Likes
TA-05 ver.2
Old 12-31-2009, 02:05 AM
  #571
bl4
bl4's Avatar
Hi anyone have the setting for touring for Ver.2? Thks!
bl4 is offline
Old 12-31-2009, 06:53 AM
  #572
Skitee's Avatar
Originally Posted by Akudou
Would anyone save me the trouble by giving me Tamiya's TA-05 IFS carbon damper stay part number?
Mezan, anyluck on stargek? And where else do you get your Tamiya's part in singapore?
Tamiya Part number is 53994
Skitee is offline
Old 12-31-2009, 03:45 PM
  #573
Hi all,
Just picked up this kit, is there anything that needs upgrading right away? Gonna run vta. Are there any spares I should carry?
scottlong is offline
Old 01-01-2010, 07:56 PM
  #574
Pingers's Avatar
Originally Posted by fgranados75
Hi, I need help finding the right gears for my car.
I will be racing with a Novak Havoc Spec Brushless System 10.5 with NiMh batteries in an asphalt parking lot, the area of the track is arround 195ft x 95 ft., I don't know the actual lenght.
Any recomendation on tires?
I have never race a touring car, so I don't even know where to start.
F.G.
Originally Posted by gashuffer
7,22FD
I actually have a question on this. In the Novak Ballistic Brushless Motor Instructions I received it recommends a FDR of 5.5 for their 10.5T system. So why would an FDR of 7.22 make sense? Just curious. In the same manual it says that a FDR of 4.0 is ideal for a 17.5 motor and I'm not sure what gearing would be good to obtain that.
Pingers is offline
Old 01-01-2010, 09:05 PM
  #575
Akudou's Avatar
You can run it stock or if your willing to upgrade it then it would be recomended to get the rocker arms + bearing set and the steering set would be advisable.
Originally Posted by scottlong
Hi all,
Akudou is offline
Old 01-01-2010, 09:49 PM
  #576
Akudou's Avatar
I am using suspension mount 1A (front) and 1D (rear). What separate suspension mount should i use?
Akudou is offline
Old 01-01-2010, 11:04 PM
  #577
tom_chang79's Avatar
Trader Rating: 13 (100%+)
I'm sticking to the stock separate suspension blocks, 1A/1XA.
I bought two pairs of those, one pair for the front and one pair for the rear.
I'm also using the 1A and 1D suspension blocks...
Trying to keep mine stock until I get better at driving this. Then start tweaking it to squeeze every last bit out of this car...
tom_chang79 is offline
Old 01-02-2010, 01:08 AM
  #578
I've been racking my brains out trying to find the pivot balls (#53709) so I can complete my TA05v2 upgrade with the aluminum hinge blocks.
Does anyone know any non-Tamiya pivot balls that will work? HPI? Xray?
Old 01-02-2010, 04:04 AM
  #579
gashuffer's Avatar
Trader Rating: 48 (100%+)
http://www.speedtechrc.com/store/ebp...id=250&id=1786
http://www.ampdraw.com/browse.php?ty...rtnumber=50994
gashuffer is offline
Old 01-02-2010, 09:50 AM
  #580
Thanks for the input. Are the rockers weak?
I'm looking to run this in vta, is there any clearance issues with the spec rims/tires or camaro body? Anyone have a base setup for this, or is the kit setup a good start?
Old 01-02-2010, 10:28 AM
  #581
Pingers's Avatar
Morning photoshoot.
Pingers is offline
Old 01-02-2010, 10:31 AM
  #582
Archie10's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Pingers
Morning photoshoot.
that's effin smexy!
Archie10 is offline
Old 01-02-2010, 02:02 PM
  #583
Thanks gashuffer, I don't know why, for the life of me, I couldn't find it...
Old 01-02-2010, 02:08 PM
  #584
Originally Posted by Archie10
that's effin smexy!
+1... Your TA05 is a beauuuuuuuut...
Old 01-02-2010, 05:56 PM
  #585
Akudou's Avatar
TA05 carbon mount spacer #53882- been wondering where do these parts belong to on the ver2
Akudou is offline
