TA-05 ver.2
#541
Hi, I need help finding the right gears for my car.
I will be racing with a Novak Havoc Spec Brushless System 10.5 with NiMh batteries in an asphalt parking lot, the area of the track is arround 195ft x 95 ft., I don't know the actual lenght.
Any recomendation on tires?
I have never race a touring car, so I don't even know where to start.
F.G.
F.G.
Primary: (spur / pinion) 110 / 34 = 3.23
Internal: (diff / center) 36 / 16 = 2.25
Tamiya TA-05 FINAL DRIVE RATIO (34t pinion): (primary x internal) 3.23 x 2.25 = 7.26
In RC drifting, you generally lean towards a higher ratio because torque is what makes the wheels spin.
#544
Just a quick questions, do Tamiya sell only the V2 tub chassis? Need one for spares (:
#545
Hey Mezan all the way from singapore. Yes i have seen Tamiya's original ver2 tub on just one or two online store. Believe there were priced at USD20plus if memory serves me right. Does stargek have any which i am curious cos i wanna get 1 myself.
With a CF Chassis it looks more impressive in my opinion. Easier to clean than tub too, I assume. But with air blower / compressor, even with tub it is find. It will be dust-free in a few seconds.
#546
Just incase you needed more of a break down.
1. This is a great forum
2. I don't know anything about cars!!
Is there any web site where I can look for car basic concepts? This is my first car and I'm starting to think that helis are much easier to set up.
Francisco G.
#548
I'm not sure if stargek have them. Have not check with them. Will check with them soon, and will let you know. As I'm also looking for one.
#549
#550
#551
You using V2 for drifting? or touring?
#552
I have quite a number of parts installed on the V2. And am still sourcing out just a few items to complete the whole hop-up as to claim it a TRF. Even most of my screws are the blue hop-ups from Tamiya. What parts are you looking for? I can help out with the part number which fits the V2. I use my chassis for drifting and occasionally TC with it.
#553
According to gasshuffer Ver2, he uses IFS bulkhead for the front and TA05 for the rear. I assume they would fit without any modifications needed. Right?
#554
Yes, the Bulkhead needed for V2 are the IFS for front and the normal TA05's bulkhead for the rear. No modification necessary.
Yes im a drifter from Brunei and so far there are 3 V2 drifting on our streets. My V2 has seen changes such as front universals, steering sets, rockerarm set with bearings, aluminium direct coupling F&R, 64 pitch pinion and spurs, Tamiya's spring (medium F&R), Stabiliser bars, suspension mounts (F&R), side brace,etc. Its a reliable machine for drifts and serves very well.
Ouh. Great to see another drifter with a Ver2! I've only changed my spur, pinion and damper only as of now. Looking forward to change the bulkhead for front and rear so it will be easier to clean.
#555
Well noted on the bulkhead. Thanks!
As of the direct coupling, its the same as TA05 right?
