TA-05 ver.2
#2341
#2342
Hi Guys, Can you use the TRF shocks for a Mini on a TA05?
#2345
Thanks guys. I found a V2 with the upgrade parts so I will have the correct shocks but I do have another question: How important is it to have the short arms and 416 uprights that were in the R kit? Worth buying?
#2346
I found a Exotek EX05 Chassis BNIP on eBay and ordered it right away haha. Payed 130 for it which is more than what it sold for from Exotek, but I think it'll be worth it. Stoked to start the transformation of my project TA05.
#2347
Just my 2$
#2348
The 416 arms and uprights are the reinforced plastic which tend not to strip as fast as the softer plastic ones. Although some like the softer Plastic because they will give a little more when you hit and their not as brittle. Plus the plastic ones are a little cheaper!
Just my 2$
Just my 2$
#2349
The TA05v2 and 416 have the same arm length. If you wanted to run a narrow front track using A/A blocks, you will need to go to the 42mm. C/C can use 46mm.
#2350
does anybody know if the alu gear diff outdrives of a TRF417 fit the TA05 gear diff? I guess only the short version will fit the gear diff, probably the same issue as with a TA06 gear diff.
#2353
