bearing durability
The $1 bearings you change often are best for durability.$20 in bearings every 3-4 gallons is a lot less expensive than having a crappy day at the track.Unless you can use 8X16 diff bearings that last 5-6 gal,then its only $8 in wheel bearings & you can do that every 2-3 gal just to be safe.When you can get good bearings for a buck a piece then cleaning & lubing expensive bearings is for the birds.
I use Avid & never had a problem with them lasting longer than I stated above of course I never had a problem when I used the Protek ones either.
