TC3 Forum
....one problem [w/ quite a few solutions]
....so, the steerin' prob./solution.....that's a good point with the ill-functioning dif. - sorry for the long-winded attempt @ explainin' .....& the rock in the steering rack....I would have over-looked also:Ya' learn somthin' new everyday.....
Wallstreet- Check the servo saver, make sure it is tight. If loose it can cause loss of control. Also, try to isolate the problem as to the front or back of the car by removing the shaft, diffs, or dog bones. Test the car in 2wd rear, 2 wd front, and see if you can isolate it to one end of the car.
Hope this helps.
Hope this helps.
alright i will check that out and see what i come up with
Originally posted by PaZ
mistercrash- yea all the numbers were the right ones.
Now how do i buld it so i know before i order it a link to a site would do
It can also be found on the Team Associated site. Go to their R/C Links page, then look for "TC3 Mods"
What's the best way to set tweak?
cheers MisterCrash, i just got the whole lot of ebay for 7 quid!
hey does anyone have a goood setup for a BMI tc3 on carpet. Not a very open track small and all inside turns. please PM me with a setup i would greatly appreachate it
is your car tweaked?
Originally posted by wallstreet
I have a question for an tc3 guy to please pm me or post answers to help me out. I just started driving my tc3 and the car is always pulling to the right or the left on full throttle. I have tried to get it close with my radio, but i just cant seem to get it going pretty straight.
ALL TIPS AND ANSWERS ARE WELCOMED
PLEASE HELP
PLEASE HELP
Can anyone answer this for me - on a stock TC3 setup, if you push the front of the car down, should you be able to make the chassis touch the track?
MIKE
MIKE
MIKE
MIKE
Thanks for the reply. It takes quite a lot of pressure, so I'm guessing that its normal. I actually have two TC3's but the other one has Tamiya TRF shocks fitted and it feels completely different, so I don't have much to go on. The TC3 I'm asking about was set up by the previous owner for carpet, and was super stiff. I just put some softer springs in it, and was surprised that I could push (firmly) on the front and the chassis would bottom out.
MIKE
MIKE
Originally posted by Nova F1 Racer
Not that I'm aware of... It depends if you are pushing with littleor no force. If it takes a lot of pressure ( and the none of the wheels are off the ground ) then it should be al right. If not then that means the car is bottoming out and control of the car is now in the hands of the car parts owner and the local hobby shop..
does anyone have a chart that i can print out that shows roll out for a tc3?
Will the TC4 top bumper brace number AS2225 fit to the TC3? If so how?
Thanks PaZ
Thanks PaZ
Hi all, I'm just getting back into racing after a 2 year hiatus. I used to run stock and mod with my TC3s.
I had lots of trouble running composite or aluminum bones with a oneway in mod, so I had to upgrade to steel. Does anyone know if *19-turn power* will require the same "beefyness" with a oneway?
