TC3 Forum
#9946
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
tom235: if you are referring to the pivot ball suspension that is from the NTC3, I once thought of doing this too. Only problem is that those parts are made for a nitro car and as such are considerably heavier than the ETC3 parts. Yes they may have an edge on tunability, but that is offset by the added weight of the car after the conversion.
rcracer333: the milling of the center brace is quite common among TC3 racers. Ive done it myself. There is a website that goes into detail on how to do this mod as well as a few others, but the link i have for is comes up "cannot find server". basically youll want to mill out about 1cm of the center brace using a drill press or dremel. it really isnt as hard as it sounds and its effects are quite noticable. once youve milled the centre brace, use some high density foam to keep the batteries pushed toward the center of the car.
http://www.mistercrash.ca/_themes/pa...ciated_tc3.htm
that is the link but it doesnt seem to work at the moment.
hope this helps
--Mike
hope this helps
--Mike
#9947
I was thinking about milling out my chace and cuting some spots out what do guys suggest?
Just go slow, take a little bit off at a time and you should be OK. I clamped my chassis to the desk so it wouldn't move. A hacksaw blade seems to be the best way to extend the battery slots.
#9948
Location: If I told you, I'd have to shoot you in the face.
I'm debating whether or not to do some cutting on my chassis. I mean I would like to lighten it up a bit, but then again, my hands aren't that steady. Might end up splicing the chassis in half...
#9949
hope this helps
--Mike
hope this helps
--Mike
http://ca.geocities.com/[email protected]/index.htm
#9950
[QUOTE]Originally posted by MikeDeadly
[B]tom235: if you are referring to the pivot ball suspension that is from the NTC3, I once thought of doing this too. Only problem is that those parts are made for a nitro car and as such are considerably heavier than the ETC3 parts. Yes they may have an edge on tunability, but that is offset by the added weight of the car after the conversion.
i am talking about the ntc3 i just think it would give you more in the long run.most the weight would on the out side and i don't think it would efect it that much.
im not sure it would be worth it was just a crazy idea i had
#9952
TC3 Mods
I know that somewhere on this fourm there was posted a website that showed how to mod the battery slots, put the Nitro TC3 steering parts on, and other mods. I have searched Google with no sucess, can someone help me with this link?
#9956
Re: TC3 Mods
#9957
Thanks!!! I always know that I can count on this forum to produce wht is needed.
#9959
I think i am going to go for it and modafie my tc3. I am going to do everything on the site. It should be perty slick when i am done.
#9960
good for you who knows u might end up with summin like my baby heres a bit of inspiration http://tinypic.com/4kcw83
i gotta blue fettish all me shells are that colour to lol
