TC3 Forum
#9721
Originally posted by RC Guru
is there like a hop up diff that comes already built or something like that?
#9722
New gearing suggestions?
I am new to RC, so I am still learning things. I am running my TC3 with stock gearing, 72T spur with a 25T pinion for 19T motors. I am wanting to start experimenting with new gearing to help learn more about the car.
Can anyone recommend some gearing or links to guides on gearing? Anything would be greatly appreciated.
Thanx.
Thanx.
#9725
ACER Ceramics
#9726
Hi Guys,
Any suggestion to remedy a few stripped diff case screws (top)?
Cos if I hit something, the screws would pop/open case as a result.....
#9727
Location: If I told you, I'd have to shoot you in the face.
I have some of those, but the screws don't come out, at least, last time I checked.. What happened? Tightened them too much? Mine were already stripped when I got it.. I wonder if putting CA Glue in it would work... it could bond to the plastic and create the threads out of glue, as a temporary fix it COULD work... don't know if it WILL.....
#9728
Buy 5/40 screws. They are a little larger, and use the same 3/32" driver. You will have to drill out the top holes of the diff case so the screw will be loose in it.
#9729
Originally posted by MikeDeadly
The composite CVD's are lighter but would really only hold up if you are only running stock. The lighter material would help you get up to speed a tad bit quicker due to the less rotating mass, but again this would only be for stock. The composite cvd's would not be able to take the stress of mod racing.
--Mike
--Mike
#9730
How many of you guys are using the direct bolt-on parts of the TC 4 on your TC 3. I´m talking about shock towers, main shaft, and the chassis stiffeners with the upper link mounts ?
#9731
#9732
G`day ppl`s,
Looking at buying a 2nd hand TC3.... is there any particular area that i should look at closely.
#9733
Hi
The CA worked temporary as for now, holding the diff case nice and tight....... another issue to solve though..car is too loud!
Do you put any lube to your gears ?
Thanks !
Thanks !
#9734
#9735
hey guyz, i used to be RC GURU changed my name, well, umm i was wondering, if you guyz know where i can get aftermarket diffs (pre-built would be nice), hop-ups basically, for a cheap decent price.
