TC3 Forum
#7308
Originally posted by lee82gx
Brian McGreevy:
does anyone in the region(continent) of Asia stock the demons?
i would love to have them,but it's really expensive for me to send money and to pay for the shipping out of USA.
Brian McGreevy:
IRS Chassis Kit for the TC3 is a work of art. But the only thing you gain from getting it is the Bling bling.
#7310
i'm prepared to pay the price,and the shipping...
but add 17% tax and it takes away my breath(literally)
#7312
like to say hi,
i have purchased a tc3 used and plan on running some touring car races, i have raced oval car for the past 14 years and thought i give this a try for a challange and to make more good friends. i have read the first like twenty pages of the thread and took in alot info on these cars. but to help me out , to keep from having to read the other 200plus pages can i get some help on some info. like
what is the formula to get roll out on a tc3 , and what is a good roll out to use.
are they any programs as for setup , gearing, etc that i can d/l for a laptop.
i have seen somewhere on the net ,, a place where it would make a gear chart for your car your running ,, can some one give me a link to that site.
also i would like to say thanks in advance to every or anyone that helps me.
BIGDON
BIGDON
#7313
Heya Don! I just bought my TC3 also and have been practicing up at HW. 3 of my buddies that used to run Oval up there and at Regency have started back as well as another friend has a TC3 on order now. Looks like some fun racing soon!
#7314
BIGDON
Go to this for tc3 setup sheet. blank need adobe to view pdf file.
http://www.teamassociated.com/racerh...nksetuptc3.pdf
As for rollout i dont know how to calculate it but i think it is how many times the motor spins for every one rotation of the tire.
Gearing Chart:
http://www.robinsonracing.com/gearratio.html
Gearing Chart:
#7315
Proficar: Tower Hobbies has the double pink/orange, but they are in limited quantity. The order i just made last week came to me in two separate packages, one from one of their distributing houses and one from the other. As usual, tires are in short supply when it comes time for the Birds. Have you picked any brushes up for your 19T motor yet? Pick up some of Putnams X-Brushes! I think you will find them to be to your liking.
Has anyone talked in detail about foam tire size on this forum? I refuse to go back 200 pages to look! It would be a great discussion for those that spend alot of time on foams. Tire size affects alot of things when it comes to setting your car up. (droop, camber rod location, etc) Last year, the popular tire size at the Birds seemed to hover around 2.23". What do you guys think?
- Dave
- Dave
#7316
58-57mm for Tire Diameter for the Birds.
I will go down there with about 4 Sets at 60mm and run them in Practice and then after the final Practice I will cut them down to 58mm and adjust my setup from there.
Last year I changed my setup after almost every qualifier. As the quals go on the traction keeps getting more and more so you have to make changes. Luckily Baker was very nice and helped me out with Setup. Last year I was running my Tires at about 59-60mm during the quals and he told me to take all my tires down to 57mm. I was losing about 1mm of Tire wear after each run.
#7317
- Dave
- Dave
Tires...eerg...I'm working on it. It seems as if fate is not allowing me to save money as far as brushes and tires.
Tire size...I think am going to cut all my sets down to like 58-59. That is where I am getting pretty good runs this season. There is definitely a noticeable advantage when using lower tires, a very expensive and aggravating advantage .
#7318
Sucks having to cut 6-7mm off a pair of $20 Tires to use them for 3-4 Runs .
If you don't do it though your car will probably Traction Roll because of the sidewall on the tire.
#7319
BIGDON
#7320
for foam tires with the TRC 30 mm ones I cut them down to 2.350 to get a little more life out of them. the rim is a little bigger so 2.230 leave very little run time on these tires.
