TC3 Forum
#5281
Registered User
Does he have a webite?
Thanks!
Thanks!
#5283
Registered User
Gotcha, thanks!
#5294
It is not hard to make a tc3 quiet. All you need is, first of all, a new pinion and spur. That should take care of most of it. Then, routine maintenance on the r&p gears (ie. cleaning each tooth thouroughly) Then clean all the bearings and re-lube them with a light bearing oil.
Also, if not using the bearing spacers, make sure the wheels are not overtightened.
One common problem is worn cvds and outdrives, they can make a TON of noise.
