Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 10-03-2009, 10:18 AM
  #1096
Trader Rating: 51 (100%+)
How is your battery being mounted in the car?
Originally Posted by InZane
Servos suitable for 1:12 pan cars works fine with the F1 cars - I'm using a JR-Racing Z3550.
Apex is offline
Old 10-03-2009, 10:55 AM
  #1097
mugler's Avatar
Default QteQ Parts for 104
QteQ is a Japanese company making high end hyper cool parts for mini-z's and looks like they have come up with some parts for 104 as well:
http://www.multiverse.jp/QTEQ/top.html
mugler is offline
Old 10-03-2009, 10:56 AM
  #1098
InZane's Avatar
I'm using saddle packs - they are fastened with a rubber O-ring, pretty much the same way as in the 1:12 CRC GenX.
Look here for more pics
InZane is offline
Old 10-03-2009, 10:59 AM
  #1099
gashuffer's Avatar
Trader Rating: 48 (100%+)
I'm using saddle packs - they are fastened with a rubber O-ring, much like the 1:12 CRC GenX.
Very nice car
gashuffer is offline
Old 10-03-2009, 12:32 PM
  #1100
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by akura2
Here's my 104 Pro that I built for the big F1 day at Tamiya last weekend, but couldn't make it due to illness in the family..
And where I notched the chassis so I could use my Orion 3400 LiPo
Super Autobacs...
excuse the crappy photo, I was in a hurry this morning... but I'll get better photos later (you would think that being a professional photographer that I would have taken a better photo... but that will come later)
Instead of notching the chassis to accomodate the bullett plugs, I cut down the plug, and they fit very nicely I used E-Flite 4mm's, and they have a "ring" that goes around them, cut them off at the ring, and solder the wire onto the flat surface thats left.
You can see the "ring" im talking about in the pic
ps excuse MY crappy pics
Attached Thumbnails Tamiya F104 Pro!-1003091524.jpg   Tamiya F104 Pro!-1003091525.jpg   Tamiya F104 Pro!-efla249-450.jpg
geeunit1014 is offline
Old 10-04-2009, 12:17 AM
  #1101
WheelNut's Avatar
Does anybody know when the Tokyo Hobby Show is going to be? I really can't wait to get a look at the new F60 kit! Rubber tires mean I'll be able to run it in the silver can GT class here in Alberta.
WheelNut is offline
Old 10-04-2009, 07:36 AM
  #1102
Oortael's Avatar
Hey Guys,
I've lost the spacer for the front wheels (BC4, 19804246). Unfortunately, I could not find one on the internet and my lhs hasn't one available. Might it be possible to use the 1.5mm spacer (19804372) of the TRF416?
Oortael is offline
Old 10-04-2009, 11:10 AM
  #1103
akura2's Avatar
Thanks for the info... the battery I'm using doesn't have the little "dip" in the front.... Notching the chassis was the only was I could go with mine....
BTW... I drove my car at Bending Corners Raceway yesterday (outdoor asphalt medium to high grip) for the first time and my car didn't have any of the "problems" people have been complaining about.... my car is silver can, with the smaller stock spur gear.... I drove it with the rear spring removed with the stock t-bar...
The car was straight as an arrow on the back straight... and the only thing I noticed was that it had some high speed understeer (not necessarily on power, just higher speed). low speed oversteer... but after a lap or two, it was really easy to get used to and compensate for... rear end was planted
Sight toe-in, stock tires, rear spring removed, stock t-bar, Team Orion 3400, Spektrum 3500, Novak XRS, negative camber setting, no tire additive....
if anyone has any ideas about the over/under steering issue, I'm all ears.. but other than that... the 104 is a keeper....
akura2 is offline
Old 10-04-2009, 11:15 AM
  #1104
akura2's Avatar
Oct. 8-11
akura2 is offline
Old 10-04-2009, 11:40 AM
  #1105
akura2's Avatar
Originally Posted by barneveld
The strange thing is that with harder front tires, the understeer is less...i did not expect that. .
the harder tires have more natural rubber in them, so they actually have more traction..... On asphalt at least
so I've heard
akura2 is offline
Old 10-04-2009, 12:37 PM
  #1106
akura2's Avatar
Originally Posted by gtypecanare
Glamor shots from last weekend.
On the Ferrari... is that vinyl or paint on the wings?
akura2 is offline
Old 10-04-2009, 01:11 PM
  #1107
fat500's Avatar
I am in need of a second f104 . If you have one pm me . Thanks, fat
mint cond and paypal please or new
fat500 is offline
Old 10-04-2009, 03:55 PM
  #1108
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Oortael
Hey Guys,
Get a pack of 53539 - 0.5, 1, 2 and 3mm spacers.
veecee is offline
Old 10-04-2009, 04:05 PM
  #1109
veecee's Avatar
Good to hear you have the F104 working well. When are you getting the understeer and oversteer - turn in, mid corner or exit? I would try tightening the friction damper a little (or maybe a slightly thicker grease) and maybe even a softer front spring (silver).
veecee is offline
Old 10-04-2009, 04:58 PM
  #1110
fat500's Avatar
I never use grease on my fricton plates. I use the low friction Teflon pads tamiya makes for the f103. The white ones. They work as well as greased reg. ones for me...just run them tighter for the same effect. tam54138
fat500 is offline
