Tamiya F104 Pro!
#9001
#54222 F104 High Traction T-Bar: http://www.tamiyausa.com/product/ite...oduct-id=54222
#51381 F104 F Parts - Suspension Arm/Front: http://www.tamiyausa.com/product/ite...oduct-id=51381
Here You can find a lot of F104 part numbers: http://www.tamiyausa.com/search.php?....x=7&image.y=7
#9002
I do know that the 104 Pro and the 104v2 uses totally different chassis, rear pod, motor mounts and a few other parts but most of the front end is the same.
#9005
F104 Pro or not to Pro
Just after a little advice on which Tamiya F1 to get. I finally have an excuse to get an F1 car but with no local racing to see what people are using.. I've turned to the forum. And apologise if these questions have been answered before.
I will probably be running 21.5 blinky on foam tyres on a low grip carpet. I was looking at the F104 Pro. Seems to have a couple of upgrades over the basic F104, which you would probably want sooner rather than later, so seems better value.. or what of the Pro Version 2, I notice that the back end is considerably different to the F104 Pro...
Are there many 'essentual' upgrades you need for the F104 Pro?
I'm leaning towards the F104 Pro, with body and wings it seems like good value over the version 2... Any thoughts?
#9008
i think the sidepods are just a look thing. there maybe a small aero difference but it would be minimal. using the sidepods does shrink the available space for esc and reciever on the sides, unless you are using a small esc then the smaller space wont be a problem
#9009
The optional side pods are just part of Tamiya's way of making the bodies as realistic as possible. A little more work to be done to finish the body.
#9011
I opted to eschew the side pods since my F1 will spend time on the track and I figured that the less parts attached would be less parts to fall of from crashes (yes, those do happen very often). Also the straighter sides allows for more room as was mentioned earlier.
Now if you really want to mount the mirrors you will need to use the side pods.
After looking at it and having it on the track I now wish that I used them for the cool factor.
#9012
You'll still want an aluminum motor mount for the Pro. If you can find a Black Special, that has the motor mount too and a body. But remember, either one of those cars has the older style body with the smaller wings. I don't know if there is a huge difference, but it's something to think about.
The V2 has a lot of nice stuff on it, but again no motor mount (why Tamiya why??). Some of the other stuff like the graphite braces are not really necessary.
I think that the V2 is the better car, but other people feel differently. I like the greater tuning options. I also feel like the car is smoother driving.
#9013
#9014
How are you guys modifying the 104pro to accept full size lipos? I just got my kit built, and my reedy 5000mah lipos dont fit unless I remove the side pods for the esc/rx (batt too wide). What I was planning on doing was making a plate that goes under the battery and still hangs off the sides like the pods to hold the esc/rx (plate sits perpendicular to chassis). I have about 2.5 mm clearance between the battery and top plate, hopefully I can find something that fits. Was just going to double side tape the plate to the chassis. Should I run the battery forward or rear?
Other ideas? Hopefully I can get something worked out before raceday sat.
