Tamiya F104 Pro!
#8806
Yeah I don't see anything wrong with it either, I will definetly be picking some up before I go up to the Tamiya track
#8807
i currently am running the tamiya aluminum motor mounts part #54166 and i would like to be able to raise my rear height more than i can currently get. Will the aluminum motor mounts off the f104ver 2 part #54356 allow me to get more ride height in the rear or is it essentially the same as the version 1 rear aluminum motor mounts????
idbdoug
idbdoug
#8811
idbdoug
idbdoug
#8813
idbdoug
idbdoug
#8815
It works well even with small dia F103 tires (about 4mm more ride height than Tamiya F104 motor mount) but it is quite expensive...
#8820
When installing the spur gear adapter for a F104 diff I noticed that the adapter itself is thicker than the spur gear. This causes a slight amount of wooble in the spur gear. Should I sand the adapter down to the same thickness as the spur gear or should I just leave it the way it is?
