Tamiya F104 Pro!
#7411
After hearing this maybe I need to upgrade the motor plates to aluminum. Anyone know if the black motor plates are still available?
#7414
Are you running the stock motor plates on the X1? I'm thinking the carbon plastic is tweaking on the X1, but on the pro the aluminum is staying true.
#7415
They should show up again. I looked everywhere online in Japan and the US. Tamiya just finished doing their inventory audit so the online shops will soon have their supplies refilled. I usually watch for f104 parts on Tq's website since they are just down the road from Tamiya.
I couldn't wait since my fellow racers peeled me into a wall at full speed and broke my carbon plastic motor mount into 2 pieces. I bought the blue ones and rattle canned them black.
#7416
http://www.rcmart.com/rc-mrr2-hopup-...=595_1075_1076
I'm going to use these for wide link setup.
#7417
Greg,
#7421
thanks robk, makes sense. one nice thing about the double tube setup is the instant visual feed back on the tweak of the chassis. if the cam lever is not at 90 degrees when the car is at rest on a level surface, then you need to re-tweak. and man was my chassis tweaked.
#7422
Well that can be an indication...but you could also just have a high spot or low spot in the tire...especially if you are using rubber tires. Or even you could have one front spring more compressed than the other...both would cause the cantilevers to not be at 90*.
#7423
It's those hard front hits that tweak me
#7424
measuring caster?
How do You guys measure caster when building custom made link setup? Is there any accurate and simple solution?
