Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 09-29-2011, 12:15 AM
  #6466
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Originally Posted by MikeR
If you have a low-pro servo then this is the best way;
http://www.exotekracing.com/f104-bolt-in-servo-mounts/
Seriously. This is the single best thing I did to my F104. Plus it looks way cooler :P
Korey Harbke is offline
Old 09-29-2011, 02:38 AM
  #6467
dfx
dfx's Avatar
Not sure if enybody's mentioned what extra trimming of body needed for exotec chassis? I'm thinking about uprades for my F104Pro with F60 body.
dfx is offline
Old 09-29-2011, 08:59 AM
  #6468
SilverShelby's Avatar
I just bought a f104x1 really like how the car handles.does anyone have a good setup for the role damper??
SilverShelby is offline
Old 09-29-2011, 09:07 AM
  #6469
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by TryHard
Thanks Mike
I used 6mm before, but I think I got the servo in the wrong place so screwed the ackerman up. Did notice the links getting close to the upper a-arms as well, will keep an eye on that.
On a different point, interesting that Hayato's car seems to be 1s... anyone know if that is a Japanese rule?
It is a Yokomo 7.4v pack with 2500mah.... nice little sleeper pack
MikeR is offline
Old 09-29-2011, 09:12 AM
  #6470
MikeR's Avatar
You would trim the inside portion of the skirt to clear the side links like so. Not that noticeable.
MikeR is offline
Old 09-29-2011, 06:31 PM
  #6471
Trader Rating: 19 (100%+)
I never realised the 104 body with the side pods would fit the exotek chassis, I jsut have my body without the side pods and i didnt need to trim anything out of the ordinary.
LordAnubis is offline
Old 09-29-2011, 06:56 PM
  #6472
MaxSp97's Avatar
But with side pontoon, it looks nicer
MaxSp97 is offline
Old 09-29-2011, 08:07 PM
  #6473
RobS's Avatar
What does everybody use to paint the front and rear wings for their cars? I'm going after the Brawn paint scheme look and was wondering what kind paint would work best on the plastic wings... Just regular Tamiya/Pactra paint?
RobS is offline
Old 09-29-2011, 09:19 PM
  #6474
texastc's Avatar
Vinyl sheet
texastc is offline
Old 09-29-2011, 09:44 PM
  #6475
mtveten's Avatar
Trader Rating: 29 (100%+)
Mike,
for the servo setup mentioned you will need to move it back 8-10mm and use ~6mm of shim to correct bumpsteer with the longer horn. with the servo positioned in the stk mounts the change in ackerman will result in slower corner speeds.
The next best thing and best tcs option is to just use the short tamiya horn minimizing bumpsteer. mounting the servo upside down in the mounts can smooth out turn in and improve mid corner through exit steering.
mtveten is offline
Old 09-29-2011, 10:01 PM
  #6476
tudor_47's Avatar
I suggest 5-6mm of spacers (depends on your servo size) and the alloy horn. You want the turnbuckles perfectly level to eliminate the bump steer. Grind under the arms if they rub the turnbuckle when the suspension is compressed and the wheels are turned.
Yes, you can slide the servo forward or back as well to adjust ackerman. Bonus points for that
Here is Hayato Matsuzaki's car with the same set up;
Any more pics of that car?
looks like a TRG111(109)..
thanks!
/johnny
tudor_47 is offline
Old 09-29-2011, 10:16 PM
  #6477
MikeR's Avatar
thanks!
/johnny
It's a modified Exotek104 with TRG front arms;
At the bottom of here
http://uf1series.com/_gallery/gallery_21.html
MikeR is offline
Old 09-29-2011, 10:24 PM
  #6478
TryHard's Avatar
Nice, I've been trying to get a Losi 92mm Lipo pack.. with the same intention, more weight at the back!
TryHard is offline
Old 09-29-2011, 10:38 PM
  #6479
Pretty sure you need to make an upper arm conversion like that Mike .
Old 09-29-2011, 10:43 PM
  #6480
tudor_47's Avatar
thanks!
/Johnny
tudor_47 is offline
