Tamiya F104 Pro!
#5551
Had a run last night and played with the tamiya tires.
conditions were low grip, cold night, and the only change to the car between rounds was the rears. Ran tamiya hards up front. I run Tekin 21.5. with boost etc. 8 min races
first up tried tamiya soft rears with the shimizu inserts that come with the shimizu rears. FXII for 15 minutes. Best Lap 25.351, Avg 26.205, Car felt very stable, and easy to get onto power. 19 Laps total 8m17. I had used these tires for 3 races earlier, so had some wear.
next race tried tamiya soft with foam insert. Treated with FXII 15 minutes. Best Lap 25.830 Avg 25.830. Car felt fine, I did feel that I couldn't hold on the throtle as early. 18 laps in total 8m.05.
Final race of night went back to first race setup and car felt even better, but I forgot to but in transponder, but I was able to finish within 1/2 sec or corally for another 19 laps.
I would recommend for low traction cold to give the Tamiya Soft rear's with the shimizu inserts a go if looking for rear traction.
#5554
could someone out there help me out. i experience really bad understeer. i have tamiya option front and rear wheels,silver front spring with a silvercan. i drive on low grip ashpelt surface with no aditives as i cant really get them. is there any setup tips i could try?
#5555
The Option rears are soft and will give the most rear traction as far as Tamiya tires go. The kit rears are also medium compound.
For more steering you can go to the kit medium fronts with the soft option rears or keep the hard fronts and go to the medium kit rears but will probably lose too much rear traction.
For additive that should be easy to get, try cleaning the tires each run with Simple Green. Works especially well on the Tamiya F104 rubber.
#5556
finally got around to testing the rc4less foam 104 tires! the Tamiya fronts wear waaay too fast.
Mantisworx independent rear suspension chassis
RC4 soft rears,super hard fronts
17.5/3s
track was rained on this morning so it was very loose but i still had plenty of grip!
http://www.youtube.com/watch?v=dP-k0IEE-gw
tires are great, after 3 full packs very little wear, normally i wear out a set of fronts every other pack at least to the point where i can barely use them.
17.5/3s
#5557
so anyone tell me what are good rubber tires for carpet with the 104?
#5558
17.5/3s
My F104 with 17.5 2S boosted is a bit of a rocket...
#5560
Option front tires are hard compound, the kit fronts are medium and will increase grip.
#5562
http://scriptasylum.com/rc_speed/top_speed.html
KV reference: http://teamtekin.com/blmotors.html
2500kv
3.25 gear ratio
2.4"dia tires
11.1v (actually 12.2 on a full charge)
even if you were able to get 25k rpms, with timing (which you are not) that still only puts you at 55 mph max with a use able gear ratio.
on this track 1/8 scale gas cars exceed 75mph!
#5563
17.5/3s
17.5/3s
#5565
You should try the Shimitzu tires. The R3 soft rear's and F3 medium fronts work well on carpet........ good luck.
http://www.tqrcracing.com/shop/produ...d=f104&pg_no=1
BM
BM
