Tamiya F104 Pro!
#4651
Abu, can you make those pictures any bigger? They are tiny! Hard to see anything!
#4654
anyone running f104w with f104rims?
#4656
#4658
#4660
#4661
Hey Mike R, you got email.
#4662
Replied thx!
For the Exotek owners out there-
I've been working on a few developments. One of them is roll stoppers to help keep the front wheels from lifting and the car from dumping over on high grip tracks. With this you can run medium soft side springs for low speed traction and the roll stops helps losing the car at high speeds. See attchd. I just drilled extra set of holes and installed 16mm screws. You can also try fuel tube or 2nd set of firm springs there also for dual rate effect.
#4665
How i can adjust tweak in the rear pod? i have the normal F104, the F60 kit
