Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 02-03-2011, 05:39 AM
  #4411
Trader Rating: 39 (100%+)
It will give you more steering when you let off the gas. On power, it may create a little push.
Jamie Hanson is offline
Old 02-03-2011, 09:24 AM
  #4412
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by tcb22185
i did ur foam on the tplate trick. on the soft tplate..
Not sure I was the one that suggested that to anyone....
the only thing i did was add a 2mm shim under the shock mount on the top deck of the car. would this give me more steering? if it does im def taking it back out..
I've never tried that... If I were to guess, I doubt raising or lowering the Shock mount on the top deck would make any noticable difference on the track... Will have to try
Special K.... any thoughts???
2-Bad is offline
Old 02-03-2011, 09:31 AM
  #4413
Trader Rating: 61 (94%+)
mr K was the one suggested glueing foam from a tc5 on the tplate.
mr k thoughts about raising the shock would be good.. they do it in pancars so its got to do some thing.
tcb22185 is offline
Old 02-03-2011, 09:57 AM
  #4414
2-Bad's Avatar
hmm, will be waiting with interest with you to see his comments. Always keen to try new stuff...
2-Bad is offline
Old 02-03-2011, 11:50 AM
  #4415
gsxr0311's Avatar
Trader Rating: 19 (100%+)
does anybody know what tires work best for outside prepped track?
gsxr0311 is offline
Old 02-03-2011, 11:52 AM
  #4416
gsxr0311's Avatar
o, sorry. i mint to say what rubber tires work best for outside prepped track?
gsxr0311 is offline
Old 02-03-2011, 01:29 PM
  #4417
robk's Avatar
Trader Rating: 22 (100%+)
are track right now does not have very tight corners. its a easey to to run. just some what bumpy. i did ur foam on the tplate trick. on the soft tplate. running the n tires up front i have a ton of steering. the only thing i did was add a 2mm shim under the shock mount on the top deck of the car. would this give me more steering? if it does im def taking it back out..
Thanks in adv.
Most of the time I feel like making the shock flatter makes the car steer more on power, like using the bridge mount on the f103 vs. the post.
Jamie is a very accomplished pan car racer, and knows his stuff. I may be wrong on my advice
robk is offline
Old 02-03-2011, 01:58 PM
  #4418
Trader Rating: 29 (100%+)
what are some of the best websites to find parts, tires and such for the f104
Mindcrimes is offline
Old 02-03-2011, 02:08 PM
  #4419
www.tqrcracing.com for most F1 parts.
tcb22185 is offline
Old 02-03-2011, 05:22 PM
  #4420
i just finished painting my f104 pro body. what should i use to cut it out with. Dremel, Hobby knife, scissors?
Old 02-03-2011, 06:59 PM
  #4421
always cut before u paint....
tcb22185 is offline
Old 02-03-2011, 07:15 PM
  #4422
Trader Rating: 13 (100%+)
Don't forget SpeedtechRC!
stitchy is offline
Old 02-03-2011, 10:01 PM
  #4423
Well I finally got the courage up to start cutting out the body Still got a long way to go:
InspGadgt is offline
Old 02-04-2011, 04:48 AM
  #4424
3rd-dan's Avatar
Mine is done
This not the final version of the car.
I have mounted Pro10 wheel adaptor for using pro10 wheels.
If i have some pics ill post it.
Attached Thumbnails Tamiya F104 Pro!-wolf.f1.jpg   Tamiya F104 Pro!-wolff1.jpg
3rd-dan is offline
Old 02-04-2011, 04:56 AM
  #4425
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
You've lost my interest 100%, now you're just running a narrow pan car
abailey21 is offline
