Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 06-09-2010, 06:41 AM
  #2866
Originally Posted by reenmachine
Aluminum can indeed oxidize, but anodizing does a good job of preventing that.
The culprit here is an effect called galling.
Aluminum is prone to seizing, and anodizing is easily worn off of threaded components. On my 1:1 car, I use an anti-seize compound called "Copaslip" which has copper dust suspended in a lubricant. It works great and is much less messy than other anti-seize products. It's available from most race shops.
jhberger is offline
Old 06-09-2010, 07:28 AM
  #2867
cyclone x's Avatar
do any of you guys use the tekin rs or fx
cyclone x is offline
Old 06-09-2010, 07:58 AM
  #2868
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I have had the 104 configured with 1S and 2S using the RS.
RedBullFiXX is offline
Old 06-09-2010, 08:45 AM
  #2869
cyclone x's Avatar
oh ur using brushless then you can deff use rs but i can never get my rs pro to work with a silver can
Old 06-09-2010, 09:17 AM
  #2870
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I've seen a Tekin RS Pro run a silver can, there's a specific wiring diagram for that. Do you have it wired right?
Greg Sharpe is offline
Old 06-09-2010, 09:22 AM
  #2871
cyclone x's Avatar
yeah i do
Old 06-09-2010, 09:29 AM
  #2872
I have also used the RS with a Silvercan, no problems at all.
Old 06-09-2010, 02:07 PM
  #2873
yeah i do
If I remember correctly, there are a couple settings within the software that should be set. Did you do that? Could just be a burnt esc. Did the magic smoke get out of the case?
Old 06-09-2010, 02:26 PM
  #2874
That is correct...you have to set the motor type correctly
InspGadgt is offline
Old 06-09-2010, 03:33 PM
  #2875
Originally Posted by TheOtherBill
Hi Faroh, if you are using foam tires you should be thinking about roll-out. The size of your rear tires will determine what gear you should be running. For the track I run on we use a roll out of 51 to 54. You will need to keep an eye on your motor temp. as you search for the right rollout. Check out
Gearchart.com for a roll out chart for your size tires.
thanks for the gearing web site it's cool by the way I'm running my tires at 50mm and spur at 93 and my pinion at 25 and it's does not make sense when I calculate it with this formula ,,, tire size X pinion X 3.142= 3927.5 is this right get back to me Thanks Faroh
Faroh of RCTV is offline
Old 06-09-2010, 06:15 PM
  #2876
cyclone x's Avatar
i know the esc isnt burnt because i used it in touring today to test so maybe ill try again and see
Old 06-09-2010, 06:43 PM
  #2877
Yeah if you used it in TC with a BL motor you have to remember to change the motor type to brushed or it won't work with the silver can motor.
Old 06-09-2010, 08:40 PM
  #2878
cyclone x's Avatar
yeah im gunna try tomorrow
just found out about TCS race in July im gunna go prob
Old 06-09-2010, 10:30 PM
  #2879
Default Lotus 79 "Black Beauty"
Hi to all F104 Pro Thread
Can anybody know if the Tamiya release Lotus 79 "Black Beauty" with F104 Pro chassis?
drover is offline
Old 06-09-2010, 10:57 PM
  #2880
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Burt....
I got a hold of a 104Pro. Oh boy, the wheels are turning already. I put one race day on it and got my ass handed to me. So many things to address. I applied a short course of corrections to see if I am out of my mind, but we'll see this Sat. This is just a skinny pan car with a funky t-bar. Should be able to make it work!
Oh, forgot to mention that I spent a scant 72 hours in Honolulu a few weeks ago. I didn't call. That was rude. I'll have to come back.
Brian
Slapmaster6000 is offline
