Tamiya F104 Pro!
#2237
#2238
problem with the upper deck
Hi!
have this car (tamiya F104 pro) but i have a problem, i like put this lipo battery "ZIPPY Flightmax 4000mAh 2S1P 25C Car Lipoly Hard Case" (itīs very good lipo) but i cannot because the upper deck block the connector of the battery lipo, some solution????
#2239
Show a photo if possible, or try Deans Ultra connections, they give proper room.
#2240
#2242
sorry to hear that, but that's what it's for
#2243
You don't need to dremel anything, but you must use the battery lock to hold the battery down and away from the upper deck.
http://www.rctech.net/forum/6873706-post12422.html
#2244
#2246
Redbullfix,
Your wires are routed very nice. Do the motor wires go through the front of the motor mounts or over the top? what is the best way to route them so the suspension action is not changed?
#2247
Hey Guys,
I bought me a Hudy (109405) setup sytem for 1:10 pan cars which i want to use for my F104. Unfortunately the original ball-bearings won't fit into the adaptors for the axles.
Which ball-bearings would fit?
Greets
Ooratel
Greets
Ooratel
#2248
#2249
Just painted and built a F60 shell and it's very heavy when complete compaired to the standard F104 shell 53 grams to 74 grams
#2250
Trader Rating: 25 (100%+)
If you're using the Deans plugs you're probably not going to have a battery "short" issue against the chassis. The car that shorted was using the banana style "plug ins" right next to the chassis---it was an accident destined to happen!!
FWIW
Tim
FWIW
Tim
