Equinox Balancer/lipo problem..help?
Ok so I think the last time I ran my lipo, I ran it a little low, and forgot to put a small charge on it, while it sat on the shelf for a week. I plug it into my Equinox balancer so I can charge it, and the ERROR LED is stuck on. I can't get it to Interface Mode to charge the damn thing, no matter what I do. Anyone have any idea what to do, or am I basically screwed?
Just to make sure you know whats going on, take a voltmeter and measure lipo voltage. I'm guessing you've overdischarged one or both cells. Take lipo and using NiMH setting, charge lipo at .5amp or 1amp until voltage is back up over minimum. Monitor this carefully while charging. Stop charging as soon as voltage is back over minimum and switch back to your normal lipo charge/balance charging. You can try charging alone w/o balancer, but if lipo is below min voltage, lipo charge routine may give you an error as well.
Starting voltage now above minimum should make everything ok. Watch lipo for a few cycles and if cell doesn't puff you're prob good.
To get the best idea of what is going on, you'd need to get a voltmeter and test the cell voltages. I suspect that you ran it too low, and now the balancer is refusing to charge it. According to the Equinox manual, the Error LED should be blinking a code. 1, 2, or 3 flashes. Is yours doing that?
This is a typical recovery trick I've seen used with success for a lot of cases.
