MM 5700 Setup - NiMh and LiPo Help
You need to set the lvc to either auto or some voltage value if running lipo (like 6.2v). NiMH has bigger voltage drops so the 2 won't be compatible on same esc with the lvc setup for lipo. Not sure what to tell you to use for NiMh as far as a lvc, I'd try setting it off and run till see the car slow down. Then its time for re-charging.
If the 5700 was like the combo I bought the lvc is set off when its shipped.
read the manual on how to turn the LVC on because like the other guys said it ships to you turned off. The castle link that comes with it makes it easy to plug up and turn it on though.
You dont HAVE to have the LVC set on your ESC to run lipo. Yes it is smart but it is still going to run just fine on a lipo with it turned off. Im not recommending running a lipo with no LVC but alot of guys do and dont have problems as long as they keep a eye on their watch. I would for sure use it at first and clock your runtimes to get an idea. Like I said Im not in anyway recommending this but its not a must have.
