Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread.
#227
John
It's been quite some time since anyone posted here, so hopefully you catch up with this.
You emailed me a copy of your spreadsheet a couple months back, thanks! Just finally getting started with my whole dyno/data logging project. We have a group from our club that will be working together on this. To keep everyone on the same page we will be following the "testing" outline below.
1) On the Sentry Dyno - test all of our relevant motor/timing combinations.
2) Process each set of data through your spreadsheet to establish baseline data for each configuration.
3) Establish predicted gearing values for each configuration
4) Install Sentry in the car and make comparative runs based on the dyno studies. Attempt to optimize in-car data to the baseline dyno data.
This should get us as close as possible to being able to use the maximum each configuration is capable of. Of course we still have to put a smooth run together from the transmitter end of things or it really doesn't much matter.
#229
John,
Forgive my recall on my Physics formulas, it's been awhile.
For my testing calculations I need to have an accurate Moment of Inertia for the Flywheel and rotor. My recall keeps looking like : MI = 1/2 (M)ass*(r)adius ^2? Mass should be measured in kg?
I am testing 1S 3.7v brushless 17.5 and 13.5 with ROAR 12.3mm & 12.5mm rotors. This is for 1/12th and WGT classes, onroad - carpet, dynoed on an aluminum fantom flywheel.
Thanks in advance!
Aaron
Thanks in advance!
Aaron
#232
Homade Dyno Reaches Production
McPappy Brushless Motor and Gear Dyno
The homemade brushless motor dyno described in the following thread has now reached Production. McPappy –The makers of a deluxe oval pan car The Dart 2.5 have taken on this challenge.
The McPappy Dyno package includes everything in photo 1, which I just received. You supply a speed controller (the one from your car will work fine) A servo tester to start and stop the test (or your transmitter and receiver), a Novak Sentry for data acquisition, and your test motor.
The most accurate data will be obtained by spinning up the supplied flywheel until near max RPM. The sentry will gather the data, you will copy and paste it onto the supplied (shareware) spreadsheet that was written in the thread above by Matnin and Myself. A power curve will be generated with an accurate Maximum Power calculated.
The dyno has additional flexibility. You can run your 21.5 slave motor which is hooked up to a bank of resistors with the test motor. An approximate power will be calculated which should be very helpful for comparison testing.
Additionally, the test motor can power the slave through a set of gears. We have all guessed at the power loss in a single set of gears (12% or so). Now a precise test will be available. You might be able to see if there is any noticeable difference in friction between the big pinion big spur vs little pinion and little spur of the same ratio.
These latter two test are not included in the software as yet. This is my task at present.
The following pictures 2-5 show McPappy’s Prototype Dyno which may differ slightly with my build.
Follow the slave motor development right here. Please feel free to add your input. This is the plan
Run a motor with the flywheel and get an accurate power curve including efficiency.
Use Electrical Formulas to calculate the power output of the slave. The sentry has the ability to test volts and amps accross the resistors. Use an efficiency number from an RPM chart to correct the power for losses. Once accomplished this should get us a quick power number and may work better with the Sentrys data aquisition rate.
John
John
#234
Hanulec- I have not personally used the
Eagle Tree For Data Aquisition. I think I went to the web site once and thought it suitable, but not better. If you have used it please make a post. Data aquisition rate is somewhat of a problem when running a flywheel test. We get 10 data points a second. With a powerful motor a lot happens in that first second. Especially with the Fantom aluminum flywheel. What we do is just use the middle part of the test which is quite smooth for our flywheel run and also use a heavier flywheel on less powerful motors.
john
john
#236
I believe the eagle tree data eLogger v4 can do up to 50 samples per second.
I had the v3 eLogger yet promptly returned it because I couldn't get consistent rpm data.
#238
I checked the Eagle tree site again. Here are some notes.
High speed logging at up to 50Hz (increased from 10Hz).
This means and increase from 10 data points a second to 50 points a second. Very Nice, but it is version 4 which you may or may not have. The car version has an adjustable data rate.
Compatible with excell
This means you can cut and paste data from the logger output into excell. This means you could use it instead of the Sentry.
#240
