The Speed Passion Thread
Well took it to the track today and got the servo steering with the tx so thats good, after calibrating the throttle still no luck with that. Tried a different motor still nothing, not my trackstar motor. Rx binds or the steering wouldnt work. If anyone can help I think I narrowed it down to the reventon S esc or the throttle calibration. Usedthe manual throttle cal settings and get all the beeps and even see the motor and belt budging but after shutting down the rx and powering back on still no response from the throttle ! Anyone ?
Hey I'm looking for the Speed Passion LCD ESC Programing Box. I cannot find one anywhere, can someone help me out? Can I use a hobby wing box?
If your servo is moving then maybe something else is just wired wrong. Maybe you need to reverse the throttle on your radio then do the calibration.
Dyno results of MMM 21.5 with green board. Timing full right at 57*
Timing at full left 43*
Does the Reventon wireless bluetooth module give live rpm, motor temp, esc temp readings or is it only for changing settings ?
Ok helpful racers, after wading through and not finding what Im looking for I would like to know if the Reventon S is good for F1 or would the R be better. Also, the GT2.1 is on massive sale so I was looking at that one as well. While we're at it, I snapped off one of the micro screws in my 2.1 pro. Any ideas how to get that little sucker out?
If space is at a premium on your F1 like most are, you may consider the 2.1. The wires mount lower on the GT. If you look at the Reventon's the receiver wires plug in at the top of the ESC.
I used a Cirtix on my F1 which has a similar setup. I cut the tabs low and hard wired the receiver and on/off wires on to save some space.
Lrp x20/speed passion
Can anybody tell me if the speed passion pro 1.1 will run lrp x20 motors? Does anybody use this combo?
In case you missed it or were not on the original pre-order that sponsored guys were part of you can get the new 2014 Speed Passion apparel here. The pre-order will be live for about 2 weeks.
http://nexusinfx.com/shop/
Thanks for the help guys. I picked up both the Reventon R and the GT2.1 since it was only $54. It looks like I can use either since the F103 seems to have lots of real estate for ESCs.
So I only have 3 race days on my Reventon R and I am having problems. I have no power to the esc with a lipo...I can connect the esc to my computer via programmer and I see lights, but when I plug a battery in and flip the switch, nothing. Any help before I throw it all away and but something higher end?
