The Speed Passion Thread
Thanks for the reply "dan_vector"
I tried 3 sensor wires, all of them tested with other ESCs. Also tested them for continuity with a multimeter.
I re-did the transmitter calibration several times (at least 10 times), always the same result.
I asked here, because I was ran out of ideas to test.
Thanks again.
Thanks again.
Gday all,
Quick question.
Has anyone experienced a Reventon Pro cutting out i.e. turning off landing jumps??
I tried a new Sensor wire, checked connection and solder, with no success.
Im going to resolder the terminals check the capacitor, pull the lower housing off and give it a good clean.
Has anyone else experienced this and found a solution.
I had it occur once per race, usually from jumping.
Quick question.
Gday all,
Quick question.
Quick question.
If it still does it after checking all the external solder joints and receiver connections it maybe worth eyeing up the mainboard soldering or asking SP if they are able to exchange it.
hey...im trying to update my SP GT 2.0 pro to blinky mode software(HW 508 no timing)...but when i try to update through usb link it says this "The current version (V3.0_120428STOCK) can not be updated to the version (V3_508_No Timing)!" Can someone help me? I'm running the esc with a 17.5 and it needs to be blinky...any suggestions?
using the HW 2 in 1 pro LCD box FW is HW v1.08_120504
esc fw is V3.0_120428STOCK
Gday all,
Quick question.
Quick question.
version 4 motors
Any update on the spec v4 17.5 and13.5 release dates?
I run a Savox 1258 but I have never had issues with brown outs since going away from spektrum receivers and now using HobbyKing Orange Rx ones.
Thanks for the suggestions hopefully it fixes it
I have the Reventon Pro 1.1 EX. Am I going to need to install a battery pack on my receiver running 1S 1/12 scale? Everything seems to work ok without one at the moment.
The EX version of the Reventon Pro 1.1 is designed for 1 cell. It has a built in booster for the radio. Just update the firmware to the latest version and run it. It works fantastic in 1/12th scale.
Cool, thanks~!
Can one set say drag brake to a "Custom" value in the reventon R ?
I can not figure out how or if its posible
Im running the Mod software that came on it from the factory
Anyone know a phone number to call Speed Power RC in Chicago(SP US warehouse)? I sent in a broken Reventon Pro. Was promised a replacement via the chat on the site, but that was a week ago. Emails go responded to.
PM me the details of your RMA and I will look into it.
Tuning Haus wins
Chris Vogan won both USGT and USVTA using Speed Passion ESCs at the 2014 Tuning Huas Party!
USGT Car
-Hot Bodies TCXX with Arrowmax Aluminum Chassis
-Speed Passion Reventon Pro EX ESC
VTA Car
-Hot Bodies TCXX
-Speed Passion Reventon Stock Club Race ESC
USGT Car
VTA Car
-Hot Bodies TCXX
