The Speed Passion Thread >
Like Tree57Likes
Old 12-07-2009, 07:31 AM
  #1246
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
Here's a RS link for the Speed Passion software you guys can use until the new Speed Passion site loads it's new downloads section
(Just click free user unless you're a premium RS member)
Code:
http://rapidshare.com/files/317579564/USBV131_V150June2nd2009.rar
abailey21 is offline
Old 12-07-2009, 07:35 AM
  #1247
abailey21's Avatar
Originally Posted by Cain
email sent.
Here is a question for those running VTA. I am running a Speed Passion GT2.0 ESC, and I am using full DRRS setting as well as the Full Timing setting. The car feels great on the top end, but compared to the really fast guy, it doesn't have as much punch in the infield. I am wondering if I am setting something wrong as far as the DRRS setting, which from my understanding is for punch control? I have it turned up to 8, which I thought was no DRRS, but could I actually be doing full limiting instead? (don't have my card with me right now, just wanting to confirm).
What does your gearing look like?
I.E. 90/48 or something like 118/24????
Old 12-07-2009, 08:01 AM
  #1248
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
For gearing my FDR right now is about 4.25 . Feels perfect top end wise.
I am however using a Tekin Redline 21.5 motor . The motor though is not getting hot, its like 120 degrees max coming off the track, while other guys in the hunt using the ballistics are getting in the 160s. I haven't played with the physical timing on the motor itself (coming from a sensorless background here) as I was thinking that whats in the software matters versus what the motor is set too, so I just left it at from the factory.
Cain is offline
Old 12-07-2009, 08:06 AM
  #1249
abailey21's Avatar
I mean physically what spur/pinion combo are you running? Like Small spur huge pinion, or huge spur and small pinion?
Old 12-07-2009, 08:11 AM
  #1250
Tech Legend
Cain's Avatar
sorry, I am using a 62T Spur and a 34T pinion. The pinion is a lightweight aluminum one.
Cain is offline
Old 12-07-2009, 08:21 AM
  #1251
abailey21's Avatar
2 things you can do:
1. change your gearing utilizing the same FDR, try a larger spur and smaller pinion that will still end in a 4.25ish FDR. Some people say this makes zero difference some people swear buy it.
I have been told (I can't prove it because I'm a crappy driver and I can't feel it) but if you run a larger spur and smaller pinion you will get back some of the natural torque of the motor theoretically
2. you can also mess with the timing but that's more of a fine tuning top end than torque
Old 12-07-2009, 08:36 AM
  #1252
Tech Legend
Cain's Avatar
thanks adam. I'll see what I can do. I have a Speed Passion GT2.0 from about early June, I am wondering if I am off also on what software I should be using too.
Anyway to tell what software currently is on a system without the LCD Programmer card?
Also, big thanks too, spoke with Shawn and he is going to help me out with the LCD Card since I am waiting for the SA V2 to come in and use that. I really appreciate that!
Lastly, did you guys get in some V3 21.5s? Maybe my Tekin and Speed Passion setup isn't playing nice together!
Cain is offline
Old 12-07-2009, 08:41 AM
  #1253
abailey21's Avatar
Yeah the LCD card is on the way, there is no way to tell what software is on the ESC without the card and USB link running.
I would use the 312 for the 21.5 class, but just like now MAKE SURE the timing and DRRS are maxed out, that software doesn't like settings below maxed out
And yes, i have V3 21.5's
Old 12-07-2009, 09:26 AM
  #1254
dsyed1's Avatar
Code:
Thanks!!
dsyed1 is offline
Old 12-07-2009, 09:34 AM
  #1255
abailey21's Avatar
Originally Posted by dsyed1
Thanks!!
Guess I don't need to email you back now lol
Old 12-07-2009, 09:42 AM
  #1256
dsyed1's Avatar
Yep I am good, just downloaded the file and will be upgrading the software later today when I get home..
I will be testing the GT 2.0 Pro ESC with SP 17.5 V3 motor this week, I ran the v3 motor with SPX earlier really liked how the motor ran... very cool but was not able to get the spx to kick in the turbo or variable timing early enough... i had to use negative exponential on throttle (on my dx7) to get it going properly but then the throttle control was not as smooth as expected but the motor was definitly very fast
none the less will be testing the SP brushless combo to see how they perform together on my xray t2 08/09... at this point wondering if anyone else has been running the v3 17.5 motor with gt 2.0 pro esc and if they had any recommendations on good starting point for the FDR...
i am running on a 100 feet by 50 feet track ... straight away is about 95 feet and change and current FDR is exactly at 5.0
thanks!
dsyed1 is offline
Old 12-07-2009, 12:13 PM
  #1257
Joey4875's Avatar
whats the deal with the gearing for the new motor turned timing up and is super slower
Joey4875 is offline
Old 12-07-2009, 12:16 PM
  #1258
abailey21's Avatar
and that's exactly what I saw as well.
So I went back to lower timing and higher gearing.
It's a proven fact you'll get WAY more out of gearing than timing,
unless heat is what your after
I am of course speaking of the static timing in motors, not ESC's
Old 12-07-2009, 12:17 PM
  #1259
Tech Legend
Cain's Avatar
here is a general question. What is a good temp range to be in to know if you should go up on timing, down on timing, etc.?
Cain is offline
Old 12-07-2009, 12:53 PM
  #1260
Super Moderator
charlie_b's Avatar
I did some testing yesterday in our outdoor track that is 170x70.
what i have found is with the exact same gearing as the older v2.0 17.5 and 13.5. the motors ran an average of 10-15 degrees cooler. As i geared it up(for kicks) the motors race even cooler.
My 13.5 v3.0 after a 5 minute run, i temped at 98 degrees on the endbell. and that was 3 teeth higher than previous.
This was with NO motor timing advance. I think out of the box, the timing should not be touched and the motors are excellent as they are. I will still test them with some Motor timing and see the results. Ill keep you all posted.
charlie_b is offline
