The Speed Passion Thread >
Like Tree57Likes
Old 09-24-2012, 03:17 AM
  #10051
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by onekiwi
OK so its not the cheaper box that is included its the proper one that you had to buy separately before
I think I might be getting 2 different esc mixed up DOH!!
its the aftermarket lcd program box for all reventon series esc's mate....
blade072 is offline
Old 09-24-2012, 07:47 AM
  #10052
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
there reventon 's esc come with their own lcd programming box , not sure if the older ones will work with it.
Marcos.J is offline
Old 09-24-2012, 08:47 AM
  #10053
Trader Rating: 17 (100%+)
Originally Posted by rosey1990
Has there been a release date announced for the boost software? I blew my speedo up in the rain today, and I was hoping to replace it with the Reventon Pro. I need the boosted software by 3 weeks from now, how likely is it that it will be released in that time frame?
Originally Posted by trickedout
Reventon pro is in stock in USA warehouse with a price update, go check it out also sounding like an October release on boost profiles...hopefully the first part of October.
Boost software STOCK1, for motor 3.5T to 9.5T will be release this week...not October, however, we are still trying to improve the same software for 10.5 to 21.5T boost motor as well as the boost software for REVENTON R, and that will be like 3-4th week of October. Once they are all completed it will only be one STOCK1 software used for 3.5T to 21.5T...
We are having 2 teams to work on boost MOD and boost STOCK, once they are completed, we will merge them into 1 final STOCK1.
1st stage of STOCK 1 software testing is completed...my Schumacher cannot survived the power of the boost 4.0T with 72mph speed..after blew up 2 rear diffs, 3 rear belts and 2 sets of tires blew up, I ran out of parts and that was with only 2 packs of batteries run....afterall, I can't handle MOD, period, I am slow....
Solara is offline
Old 09-24-2012, 08:50 AM
  #10054
Originally Posted by Slayer1904
This is really unfortunate but a 2nd reventon pro is having this same issue with me.
I soldered up another new one, went out and raced a race with it. It worked just fine.
Brought it home after the race was over went to take it out of the default mod 0 program to put into stock mode and again i've lost everything but steering.
I tried returning the ESC back to Mod 0 and now again I get nothing, just steering.
I've been programming esc's with castle links hot wires everything and have never ever had an issue.
I've calibrated after program changes, turned off both turned them back on DONE EVERYTHING and I get nothing.
I consider myself RC savvy and computer savvy and have very good common sense if I thought that changing programs was going to stop the esc from working I would have never tried. But we're required to have our esc's in blink mode to race.
Please do contact our office and I will personally test your unit and try to see the problem...We had problem like that for the EARLY stage of ESC that was not for production and I think it is the software problem.
Please accept my apology for this matters...
Solara is offline
Old 09-24-2012, 09:02 AM
  #10055
NolanP's Avatar
I have a GT 2.0 Pro the I switched over to from the Hobbywing V3. It was a lot faster using boost from the GT Pro than the V3. The only way this thing is coming out of my car is...the Reventon Pro. I can't wait.
NolanP is offline
Old 09-24-2012, 09:07 AM
  #10056
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
any tips on timing board selection for stock 17.5 blinky for 1/12 and touring Solara?
Also, what advantage to do I get by going to a revention R versus the GT2.0 LPF in blinky touring? The BEC appears to be better in the GT2.0 LPF versus the revention R?
Cain is offline
Old 09-24-2012, 09:16 AM
  #10057
Come on...I am trying to save you money by not breaking your BD7, you saw the aftermath of my Schumacher after the Stock1 with 4T motor...I bet your YOKOMO parts are 3X more expensive then my Schumacher.
I will get your account setup....
Solara is offline
Old 09-24-2012, 09:18 AM
  #10058
Reventon R has better brakes and smaller footprint then LPF....the output should be very similar as they are BLINKY.
You are running indoor carpet track..? How big..? Please specify...
Solara is offline
Old 09-24-2012, 09:21 AM
  #10059
trickedout's Avatar
Trader Rating: 31 (100%+)
Hey Howard, with the release of boost timing for mod coming shortly, what is there to stop someone from using it on say 17.5 and what would be the problems if they did.
trickedout is offline
  #10060
NolanP's Avatar
I have a bag big enough of parts. Don't worry about it. If my tape doesn't rip off and the car stops traction rolling I won't have to worry about it.
NolanP is offline
Old 09-24-2012, 09:23 AM
  #10061
We will have a RELEASE NOTE for telling customer NOT to use it for 10.5 and slower motor....it has very slow LOW END to mid range and will suddenly SHIFT to 80,000 rpm...and it will cog.
Solara is offline
  #10062
Tech Legend
Cain's Avatar
Two tracks, one is 50 x 50, the other is probably 60 x 80 possibly, maybe longer.
Thanks for any help you can give. Want to order the timing boards to try, just don't want to have a bunch laying around that don't get used lol.
Also, how much of an advantage do you see using the 1 cell 17.5 versus the stock 17.5 for the Competition V3.0 motors?
Cain is offline
Old 09-24-2012, 09:27 AM
  #10063
12th scale...I know you need to run the sivler red 12.5mm rotor...but not sure about roll out...you can ask around and use the general roll out for blinky 17.5
For TC...32* timing (full left, yellow board)...gear at 4.6 and check motor temp...and that is for MMM 17.5 and you should also stock the GREEN BOARD just incase motor temp is too high (when using yellow board)...
1cell 17.5 is definitely faster/better then the regular V3 comp....MMM 17.5 is the best, and it is base off the 1cell 17.5 years ago.
Solara is offline
Old 09-24-2012, 09:39 AM
  #10064
Tech Legend
Cain's Avatar
The fatter rotors those give more punch right? would the TC benefit from it as well?
Cain is offline
Old 09-24-2012, 09:59 AM
  #10065
Trader Rating: 38 (100%+)
I wish there were more 1 cell 17.5's around but will certaintly be happy once I get the gearing set for the MMM. This weekend, TQ and 2nd qualifier (me) were both running the 1 cell 17.5 with very different set ups. I am running the stock board at max timing with an 86mm roll out. The TQ (by less than half a second) was running the +20 board at minimum with a 103mm roll out. He tried to gear down a bit for heat 2 but turned up the timing to much and ran it past 200 degress. It smelled funny but once it was cool ran the exact same as it did in the first heat during the main. Overall, great motors and like I said, I wish I had more.
linkless is offline
