The Speed Passion Thread >
Like Tree57Likes
Old 09-22-2012, 09:13 PM
  #10036
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Originally Posted by SRW141
For 17.5 blinky 1c racing. I like the green boards in both motors. V3 set at 30 and MMM set 25. That seems to have the best laps times from start to finish of the race.
Can someone explain how the sensor boards work as far as the timing ranges available?
So from what i am seeing on the green timing board is a +20 setting. Does the motor have stock 10 degrees all the time?
Also, when you go the other way on the setting, what is the minimum timing on the green board?
For Blinky 17.5 in touring, any recommendations on V3.0 Competition (non MMM motor)?
Lastly,what are peoples thoughts on the 17.5 1 cell motors. Are they that better in 1S usage for 1/12 pan? For those, what board setting is recommended?
Cain is offline
Old 09-22-2012, 09:22 PM
  #10037
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
the green board will add 20 degrees to what ever the motor has stock.
for 17.5blinky if you are in a indoor track yellowboard +30 will be good they geared that around a 4.5, i actuallly got better lap times and cooler temps with the green board.
Marcos.J is offline
Old 09-22-2012, 09:40 PM
  #10038
Tech Legend
Cain's Avatar
Thanks. So based on this:
I can go from 20 degrees to 30 degees with the green timing board on the V3.0 competition motor.
The track I am running on is indoor carpet.
Do you recommend that for both touring and 1/12 17.5 blinky?
Also, what is the stock rotor size on the V3.0 Competition motors?
Cain is offline
Old 09-23-2012, 06:53 AM
  #10039
Super Moderator
Marcos.J's Avatar
rotors i believe are 12.3mm
no idea sorry i dont race 1/12th
Marcos.J is offline
Old 09-23-2012, 01:45 PM
  #10040
NolanP's Avatar
A little birdie told me that the new boost programming for the Reventon Pro blows tires off the car.....literally. Be patient it's coming!
NolanP is offline
Old 09-23-2012, 02:53 PM
  #10041
Has there been a release date announced for the boost software? I blew my speedo up in the rain today, and I was hoping to replace it with the Reventon Pro. I need the boosted software by 3 weeks from now, how likely is it that it will be released in that time frame?
rosey1990 is offline
Old 09-23-2012, 03:04 PM
  #10042
NolanP's Avatar
It sounds like it is getting closer to go but I wouldn't tell you for sure that it will be available in 3 weeks.
Solara would have better insight. All I can tell you is it looked like it is worth the wait. Looked super fast. If you can be patient I certainly would be.
NolanP is offline
Old 09-23-2012, 06:37 PM
  #10043
Slayer1904's Avatar
may just be some bad ones out there. In general you don't hear much about the good ones. I know its no comfort though if you do get a bad one. But its a chance for Speed Passion CS to shine.
This is really unfortunate but a 2nd reventon pro is having this same issue with me.
I soldered up another new one, went out and raced a race with it. It worked just fine.
Brought it home after the race was over went to take it out of the default mod 0 program to put into stock mode and again i've lost everything but steering.
I tried returning the ESC back to Mod 0 and now again I get nothing, just steering.
I've been programming esc's with castle links hot wires everything and have never ever had an issue.
I've calibrated after program changes, turned off both turned them back on DONE EVERYTHING and I get nothing.
I consider myself RC savvy and computer savvy and have very good common sense if I thought that changing programs was going to stop the esc from working I would have never tried. But we're required to have our esc's in blink mode to race.
Slayer1904 is offline
Old 09-24-2012, 01:26 AM
  #10044
trickedout's Avatar
Trader Rating: 31 (100%+)
Reventon pro is in stock in USA warehouse with a price update, go check it out also sounding like an October release on boost profiles...hopefully the first part of October.
trickedout is offline
Old 09-24-2012, 01:40 AM
  #10045
onekiwi's Avatar
Reading a bit on the net that the pro is having problems!!! Is it software or hardware?
If its software that can be updated then thats good, but if its hardware then they will have to be sent back etc
Whats up???
onekiwi is offline
Old 09-24-2012, 02:09 AM
  #10046
trickedout's Avatar
Whats up???
Being as they are brand new there will be some bugs, most things right now seem to be software as it is just all brand new for this line. They had been doing updates and will continue to do so as problems arise.
Old 09-24-2012, 02:32 AM
  #10047
onekiwi's Avatar
OK but the USB update cable isn't released is it?
onekiwi is offline
Old 09-24-2012, 02:41 AM
  #10048
trickedout's Avatar
With the new reventon led cards, there is a USB port to connect to your pc, however the USB cord is not included, but it's just a standard 2.0 USB I believe is the name. It's a standard cable you can get anywhere like Walmart or RadioShack or if you have had smart phones or other computer accessories you likely already own one. That is all you need along with the included led box to connect and update your esc with your computer.
Old 09-24-2012, 02:49 AM
  #10049
blade072's Avatar
Trader Rating: 98 (100%+)
yep just a standard usb to mini usb cable does the trick.....
blade072 is offline
Old 09-24-2012, 02:55 AM
  #10050
onekiwi's Avatar
OK so its not the cheaper box that is included its the proper one that you had to buy separately before
I think I might be getting 2 different esc mixed up DOH!!
onekiwi is offline
