The Speed Passion Thread
#9376
Im running 10deg on motor (V3 1S 17.5)
40boost
24turbo
2000 start RPM
.2 delay
fastest slope
150rpm/deg
Gearing 5.32 FDR
ESC- HW Xtreme stock
Batteries intellect/Gens Ace 5000MAH 50C (all packs 1 month old)
Could be just me but it definetley feels like its fading, never been overheated in my hands cant speak for previous owner, Cant see it being the packs but who knows..
40boost
24turbo
2000 start RPM
.2 delay
fastest slope
150rpm/deg
Gearing 5.32 FDR
#9378
Sorry i re-read my previous post and it doesn't really make that much sense. Ok, so I got the esc off my mate and after doing the esc to receiver bind and setup(with my Spektrum radio gear) it just wont make the motor power up(run) If i disconnect the sensor wire the motor will run for about 3 seconds and then it(17.5) just cogs. I've read the paper sheets that come with the esc and it says that th esc is in sensor-less mode so that makes sense. Just need to know how to get it out of that setting. It was purchased from Hobbies crazy on Ebay not long ago and I live in New Zealand so I cant really just take it down to my local hobby store and the response time from emails from Speed Passion is to say the least, pathetic. Most of the time I dont even get a reply. I dont have a local hobby store unfortunately.
#9379
Moderator
So I threw my SP V3 1S 13.5 in a boosted class this last weekend (ROAR Region 11 Champs) and I could not get the Tekin setup to get that motor working well at all. I was destroyed on the straights no matter how much boost/turbo, and any config I tried (different RPM range, delays, etc...) and a bit soft on the infield. and almost never got even above 145*.
Any real advice would be good on what kind of a boost profile (generally) is used for the V3 1S motors better. or if a different rotor is the key, or what...
Because this thing is a dog otherwise...
#9380
#9381
I am washing my hands of Speed Passion brand. All I have is up for auction on eBay Item number: 300701881227. Not much, but I am done. Thank you for your attention.
#9382
Moderator
Solara, I can gear up, and yes it makes the motor hotter, but it bogs like mad coming out of corners. Adding 2 teeth cost me almost 2/10ths of a second in lap times, but did make my motor hot!...
Seems weird how odd these motors are about gearing and timing. No setup from a Reedy, TP, RevTech, Duo, etc... seems to work on these, or even close to working.
#9384
40boost
24turbo
2000 start RPM
.2 delay
fastest slope
150rpm/deg
Gearing 5.32 FDR
40boost
24turbo
2000 start RPM
.2 delay
fastest slope
150rpm/deg
Gearing 5.32 FDR
#9387
#9388
