The Speed Passion Thread >
Like Tree57Likes
Old 10-12-2009, 06:16 AM
  #916
wiscnitro's Avatar
Trader Rating: 22 (100%+)
Hi Everyone Had something funky happen at our race this weekend. I was running my Speed Passion GT2.0 with a 4.23 gear and Max timeing I didn't gain or lose on anyone but motor temps came off at about 150F so i droped a tooth and still motor temps 150F drop another tooth which now im at a 4.43 gear and still 150*. I have a friend that has a GT2.0 he is geared at a 4.33 and he comes off no hotter then 120 supposetly with timeing maxed. our cars are the same. No binding everything moves free. I have the aluminum motor clamp and heat sink with a fan mounted. Now this last race he used a GTB and was able to keep up with the speed passion so is the timeing realy even needed. is the GT more for large long tracks? or what the hell am I just doing wrong Thank you
wiscnitro is offline
Old 10-12-2009, 06:19 AM
  #917
M-Technic's Avatar
Trader Rating: 15 (100%+)
Max timing on the motor or the speedo?
M-Technic is offline
Old 10-12-2009, 06:32 AM
  #918
wiscnitro's Avatar
Yes. DRRS Maxed Timeing Maxed and was to start geared the same as my friend running the GT2.0 and im not faster or slower then anyone. Honestly with everything maxed (motor timeing stock) I was equal to the Novak GTB in the infield and on the streight and the GTB dosn't have a timeing feature
Old 10-12-2009, 06:46 AM
  #919
MikeXray's Avatar
Trader Rating: 73 (100%+)
What motor are you running?
MikeXray is offline
Old 10-12-2009, 06:49 AM
  #920
wiscnitro's Avatar
21.5 Novak
Old 10-12-2009, 06:54 AM
  #921
M-Technic's Avatar
21.5 Novak
I think you are going the wrong way with the gearing then, I didn't realize it's a 21.5. Try adding teeth back and getting under a 4.0 final drive (maybe 3.8 or 3.9 to start) and see where your temps are then.
Old 10-12-2009, 06:55 AM
  #922
MikeXray's Avatar
21.5 Novak
Ah, try maxing out the motor timing too, the 21.5 is a tricky one. I've also found that there are minor gains over a fairly big range of gearing. How long was your straight? if it's fairly short you may not notice any gains.
MikeXray is offline
Old 10-12-2009, 06:59 AM
  #923
wiscnitro's Avatar
Can't go lower then 4.20 (VTA rules) I was gona try a test and set the ESC timeing to 0 deg and work on gearing then when its close start working up on the ESC timeing even though I was told to max out everything can someone from Speed Passion chime in on this. I had my heat sink pop off in the last 3 min of a 5 min race and my motor temp came off at at about 175* so is there a ESC problem or dose it need a update Kinda pisses me off when a GTB is just as good and dosn't have to wory about motor temps and I did buy my ESC new.
Old 10-12-2009, 07:03 AM
  #924
M-Technic's Avatar
Well if you are limited to that gearing I say you need to experiment with adding timing on the motor and possibly backing off the timing on the speed control if temps are too high. With limited gearing options you will have to compensate in other ways.
Old 10-12-2009, 07:04 AM
  #925
wiscnitro's Avatar
we have a short streight (not sure how long) I can hear the motor pulling into a higher range about 3/4 down the streight but infield dosnt help and this weekend showed that the Novak GTB is just as good in performance as the GT2.0 I didn't have any metter accleration or top end then the guys using a GTB
Old 10-12-2009, 07:08 AM
  #926
M-Technic's Avatar
Don't give up on it yet. Every motor and speedo combination have their own little sweet spot. It can take some time to find it.
Old 10-12-2009, 07:09 AM
  #927
wiscnitro's Avatar
im gonna try 0 esc timeing and work on all gearing since thats what the GTB is no timeing advance on the esc. I see on the speed passion site there is a update for stock class its supposed to improve bottom end power from the speed passion site
For GT2.0 LPF and GT2.0 Pro:
New software version number "090312a" This is software had improve the bottom end power and top speed, special for stock class.
is the update worth spending the extra $30 for the pro programer?
Old 10-12-2009, 07:16 AM
  #928
MikeXray's Avatar
Yes its good to have the ability to update the ESC, I forget that mine have the newer software. If you are only looking for acceleration and are ok on the top end spectrum, I would try gearing in the 5.0+ range with full timing and see if you get more out of the corners. The one time I ran VTA on a very tight track, we were all equal speed wise with a vast different in esc's, the car setup was much more important, you had to carry more speed into a corner because you weren't going to make it up with rip. I was running my sp2.0 at 4.3, my friend was running his at 5.2, another was running a tekin RS (not sure on gearing), another had a Sphere, all were the same. The same cars on a track with a 90' straight I could walk the car with the sphere after 1/4 of the straight by about 8ft!
MikeXray is offline
Old 10-12-2009, 07:19 AM
  #929
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Agree too. Having the Pro programmer card is a big plus if you are serious about racing. Especially if you race with guys running Tekin RS units.
Anyone running a Tekin Redline 21.5 motor and the Speed Passion GT2.0 Pro or LPF? What are some fo the settings you recommend with this combo for VTA?
Cain is offline
Old 10-12-2009, 07:54 AM
  #930
Default SP GT2 PRO
I have a few questions ref my GT2, At the moment Im not running the pack of 4 power caps that came in the kit?? should I be and what difference will it make. I currently run 13.5 using an Sp motor. The power caps that came with the esc take up a lot of room is there any thing else I could use that is smaller.
Im about to start the indoor carpet season here in the UK, Racing 13.5 with rubber tyres any advise on esc settings Timing etc.
FLAT OUT is offline
