The Speed Passion Thread
#8716
You will notice that the 6.5 and 7.5 are much easier on your "happy trigger finger". If the main straight is not too long (say 20m-30m)then you can gear and boost the 6.5 to accelerate and top speed the same as a non-boost + max can timing 4.5. I think the major difference was the 4.5 had much stronger max brakes but that was irrelevant as you should adjust for this to make sure belts aren't skipping.
#8717
Normally i remove the rear shim , this is about 0.5mm thick then add 1 X 0.3mm on the back of the rotor and 1 x 0.3 on the front , this gives the smallest amount of play , but ehough for warming up.
It is sometimes a lottery , i have had motors take 2 or 3 shims to remove the play and others were good , I also tried adding the 0.5mm shim to the front of the rotor , but it was a bit close to the sensor board
#8719
yeah we saw this with ETS , there was some cheating b#%^rds buying 100 motors and 100 speedos then picking the quickest combo !!!!!
He was found to be cheating at the last ETS and was removed from the rankings.
BUT i have dyno'd a lot of my own motors and position of the end bell makes a huge differance , the end bell can go on 3 places and i moved it round untill i got the best RPM's this made a differance of 5000 RPM on some V3 motors , Also shim the rotor towards the sensor , at higher revs the rotor will move away from the sensor and you can get missed senses on the motor , tis drops the revs down slightly.
This is the world of 0 timing / fixed gearing we are in now in Europe
#8720
The track i race at is really small . Just have stock display so cant change boost.
What Timing on esc and Where should i be in Fdr ?
Also: Maybe i should change to Level "smooth" shouldnt this make my car esier too drive?
#8721
#8722
http://www.speedpassion.net/uploadfi...C%20RcTech.jpg
Try to be more conservative than this setup at first especially with boost acceleration,turbo delay and FDR because your track is small.
For the 4.5T, I have been running max timing on motor and zero boost/turbo on 110323. FDR was 8.07.
I always run with Level 3 DDRS in mod and do fine tuning with my radio's throttle curve. It is up to you how you want to tune the "punch"
#8724
I have been using 110323 software and v3.0 6.5T with Phil's setup. Only minor difference is turbo delay 0.2s, Boost Acc 450rpm/deg and 7.38 FDR because my track is smaller that the setup's. I also use a heatsink + fan
Will try the setup. But not Boost or turbo delay, cant change that because i dont have the optional programbox.
#8725
#8726
#8727
#8728
#8729
I will be looking for a 17.5 2S WGT speedo set up soon for my GT2.0pro
#8730
Throttle setting problem
Hi all
Have a question regarding setting a Cirtix speedy using a Spektrum DX2S transmitter.
Set up the throttle as per instruction, all good, but when you move the throttle from the neutral point you have to move it about 4 to 5mm before the motor runs, it gets full throttle ok, I do not have this when setting it to my Sanwa MT4 transmitter.
Has any one had this problem, have tried a different speedy and still had the same problem.
Regards
Gary
Regards
Gary
