The Speed Passion Thread
#8328
But if I do have new setup...I will post on the site, keep checking the setup page here..
http://www.speedpassion.net/us/escsetup.asp?page=1&t=4
#8329
Hi, does anyone have an approx FDR for the following combo?
Running a GT 2.0 lpf ESC and 21.5T Competition 3.0 motor. Its on a med/large technical track with medium traction (asphalt). Rubber tires. Supercharger function is permitted.
Cheers
Cheers
#8330
Is this in a TC? Carpet or asphalt? Boosted or blinky?
Solara, Here at Fastlane in MO, there are still a few guys running boosted and I could understand that difference going from blinky to boost. I will be testing more tomorrow night in blinky mode to try to find the right fdr.
Thanks for being close by. Another reason I choose to run SP!!
#8331
this is on a TC boosted asphalt track it is a large track 65m front straight and 40 rear
i have the standard timing on the MMM with a 40 boost and a 24 turbo running a 7.1-7.4 FDR dropping adding a tooth on the pinion have a data logger coming so we can start setting the correct boost start RPM i have it on 3000 at the moment but i think this might be a bit low 4000 might be better
it took me 8 battarys with the last 2 batterines running the full 6m30
#8332
If I remember correctly, you guys are running boosted 17.5 right..? If so...7 or even 8 is about right (depends on the size of the track). Here in US we are dropping the boosted class and most of us are running no timing now...so there might not be too much setup sheet to share about boosted 17.5 or any boosted class....
is there going to be a APP update so the 323 stock software will be on the I phone ? the apps a great idea
#8335
#8338
i have a older cirtix esc that i was going to use in a 17.5 no timing class. I sow that there is a new one out. I sow that the esc wire and switch wires are not plug in instead of solding them to the board.
is that the only difference?
thanks.
thanks.
