The Speed Passion Thread
#7006
What I dont understand is how someone can purchase the new 2.1 gt ex speedo with the advertised Supercharger software as stated above and then receive it and it not have those functions and be told you have to have to buy a separate programmer card to get those functions.
I need a new esc within the next 2wks and I am on the fence between the 2.1 pro stock and a kinetic. The only thing holding me back from getting the pro stock now is I keep getting conflicting answers as to if the Included card that comes with the esc can adjust the supercharger settings. Some ppl say it can then others say settings 1-10 only appear. Which is it? Should you be able to set the supercharger settings with the included card? Yeah I know you can buy the extra card for $30 but is it to much to ask to be able to used adveritised options without having to purchase something else. And on top of that I would buy the box but its never instock.
#7007
#7008
speedpassion v3 rotor snaped
my speedpassion v3 13.5 brushless motor was making a right noise so i took it apart to find that the long pin where you connect pinion had come away from the main rotor i think the motor is great never let me down before so i have ordered another v3 13.5 motor what can i do to stop this happening again the car it goes on is a xray t3 thanks for any replies
#7009
Also, what kind of noise were you hearing?
#7010
#7011
yes i meant main axle on the rotor came apart so rotor was in two bits the noise was like spur gear and pinion were to tight but they were not it was a grinding noise
#7012
Hi Guys, i had an issue yesterday, in practice, i had no control over my car, it had no steering and kept accelerating . so i got it back to the pits, and rebound my reciever, and tried a different battery. i worked the steering for about 30-40 seconds, lock to lock. then it went on its own. it kept going lock to lock with out me touching my radio. i tried to reflash software, rebind reciever, then i went to recalibrate. on first beep, i pressed the red button again for throttle end point, and the buzzer just stayed on, no beeps, just constant sound. i had to turn it off. and when i turned it back on, it would not power up the reciever. i took the bottom case off, and blew everythign out. could not see any issues. and still would not power up the receiver. so i was done for the day after 2 laps. no matter i tried with everything unplugged, different batteries, sensor no sensor. and even other peoples receivers. nothing. has anyone experienced this before, and what can be done to repair, or fix it. thanks.
#7014
#7015
I think it is your TRANSMITTER and RECEIVER both....see you can borrow a totally different set of radio and try it. I always has a set of FM or even AM $20 radio system for me to trouble shooting all the possible error. Give that a try.....it does not seems like the ESC problem because your steering is not working at the beginning.
anyhow, i will send it to AU distributor, and see if it can be repaired.
#7016
Just got a GT2.1 EX to run in a GT car. Can I use the Hobbywing LCD box to update software on it? Do I need to use Speedpassion software and can I use it with the Hobbywing box?
#7017
Hi all
When using 508 zero timing what colour led is ment to flash ( i get a red flashing led is this right ? )
#7020
i bought a Hobbywing 2 in 1 update box as Speed passion are sold out and back order
how do i put the Speed passion softwere onto it ???
Thanks Phil
Thanks Phil
