The Speed Passion Thread
#4726
OK, sorry.
Thanks for the comments.
Track is tight twisty indoor carpet, Losi fixed timing 13.5T. FDR 6.17 on a Tamiya 416WE.
ESC settings:
4/7
9/5
12/3
13/2
14/3
15/7
I know these are pretty soft settings, but with the 422 f/w the car had plenty of punch. Now with the 528 it seems very soft and picks up speed after what feels like a 2 second delay (probably less really!).
Any ideas? I will try re-flashing the ESC and see if it's any different.
Cheers
ESC settings:
4/7
9/5
12/3
13/2
14/3
15/7
Cheers
#4727
YES, so does LRP.
And will I need the "black box" to set it up and tune it properly?
You will need the LCD programmer box so you can upload the latest software (which Speed Passion has their software update very frequent).
And is the speed passion unit better than the hobbywing? Or are they identical?
I never own any Hobbywing unit, so there is no comparison. All I know is my Speed Passion Gear never disappointed me so far.
#4729
Can anyone comment on the Speed passion v Hobbywing esc as Hobbywing are quite easy to get here in Australia.
#4730
I run my SP LPF, my mate runs his HW 60A. we are both using the latest stock software - same settings, same gearing. the cars are matched perfectly out of corners and down the straights.
out of the 6 races we ran, 4 of them our lap times were identical to a thousand of a second.
Each to their own with these esc's.
However one thing i do definitely prefer on the SP esc's is that the receiver wire is not hardwired into the esc. so i have a spare longer cable that i can plug straight into the esc to change settings - so i dont have to go fiddling for the esc wire in the reciever (which is hidden away).
#4731
Hi
Just tried the latest software using the recommended set up sheet for 17.5t (5.5fdr) and it goes like a rocket. My car feels to agressive out of the corners when you put in the power and also the motor was hot so what should I adjust, should I drop the sc punch down a few ? Will this cool the motor and make less aggressive when I put the power on ? I also have my motor timing set in the middle.
Thanks.
Thanks.
#4732
Super Moderator
Hi
Thanks.
Thanks.
#4733
I have it set as,
1-1
2-3
3-4
4-7
9-8
10-1
12-stage 7
13-1
14-2
15-4 (-3)
1-1
2-3
3-4
4-7
9-8
10-1
12-stage 7
13-1
14-2
15-4 (-3)
#4735
Ok ignore my post earlier as my temp sensor was playing up it's well out of calibration
What's the maximum temp the sp 17.5t motors will take ? with the recommended set up (5.5fdr) my motor was 40c ish so tried 5.0fdr didn't make much difference so tried 4.69,no temp rise and no rise on top speed how to I get my speed up, shall I go lower on my fdr or move the motor timing all the way to maximum currently it's mid way.
Track is outdoor and quite a long straight I guess about 45m, and my car seems to hit maximum speed way to early.
I also tried the SC boost on Max.
How do I get the bost to come on later, I want it to come on for the straight but not everywhere else on the track which I guess it does with either the rpm deley or full thottle deley set low ?
Sorry for all the questions, but confused
#4736
and now sold out! ,
hey Adam are you with Speed Passion USA now ?
#4737
Super Moderator
#4738
Your #13 can be higher...if you are topped out too soon, allow for longer delay..i would go up on #13 until you like the feel.
Should I advance my motor timing to max as it's set in the middle or lower my fdr to get more top speed ?
Thanks.
#4740
If its a speed passion V3 motor I would try max timing on the motor. This will at least let the motor get more timing overall to play with to improve top speed. The motor will get slightly hotter though but if its at 40 degrees now I don't see any problem with adding another 5 degrees.
Mike
Mike
