The Speed Passion Thread
#4697
@Charlie
I've got a couple of questions:
do you have a usefull Esc setup (incl. gearing) to share for SP V3.0 13.5R (like the one of you for 17,5T above) with #100528 for medium size track
Despite of gearing - which parameters are the major ones I've to change if i go from medium size track to small / big?
Can I use my GT2.1 fan-less with #100528 without burning it down?
thx
thx
#4698
Hi Charlie
I have been using 422 for a while now and I am very comfortable and used to my current settings. Now that there is this "newer" software which is supposed to be "better" and "different" as you have mentioned, I want to try it out but I hate to change the settings and start all over again. Before I do it, could you please let me know if he base setup for 528 is more or less similar to 422 and what is the key item in 528 that I should be aware of. If 528 gives better performance and most importantly a cooler running motor, I will most likely make that upgrade. I am sure many other people in this thread would like to know about this. Thanks in advance for your help.
g in 2wd offroad. I set timing to 0. Gearing is normal or lower for 8.5.
#4699
@Charlie
thx
thx
Just like Charlie said, adjust to your feel and check for your temps.
#4706
defcone check out your pm.
#4707
hi guys please help..im running windows vista, ive tried downloading the 528 so many times now ive had enough. ive downloaded the zipped file,extracted the two files required , opened up v1.33 in c drive and dropped new files into the v1.33 file..it asked me if i wanted to cipy and replace excisting files which i said yes to but for the life of me it just doesnt show up when i go to the software in v1.33, i just get the original 3..my mate using windows XP did the same process and it worked fine..am i missing something using Vista ??
cheers
ps...charlie where is the setup reinhard used with 528 on the SP website, ive looked but cant find
cheers
#4708
Hi,
where is this 528 file ? I've downloaded v1.33 but all I see is 4 files, a Word doc, db3 file, ini file and the application file. Once installed all I can see is the mod file, stock no timing and the stock 422 I'm running Vista too, am I missing something
#4709
If all else fails start from scratch, like I did. Uninstall it all. The plug in the LCD, download the program for it, then while program is open, go to your start menu and right click on the app and click "open file location". Keep that open, and then download the new software. Copy that software from your download files by clicking COPY. Then go back to your LCD file that is open and click paste. The items to copy are the db3 and the version file.
Hope it works for you. I had to figure it all out myself as well.
#4710
thanks guys.. i had just got it working before reading post.. i remembered from last time with the beta software to copy/drag n drop the 2 files into v1.33 but after that the only way doing it that way is to right click the SP icon and run as administrator..worked straight away
charlie id still like to be directed to reinhards setup on SP site if poss please..i can find the old 205 stuff but not the new timed setups they use..
cheers
mark
cheers
mark
