The Speed Passion Thread >
Like Tree57Likes
Old 06-12-2010, 12:06 AM
  #4561
Just had my LPF flashed with the new software all i can say is WOW so fast. I will not be buying a lrp sxx like i had planned
Corona000 is offline
Old 06-12-2010, 12:11 AM
  #4562
Trader Rating: 23 (100%+)
Glad it helped... your 13.5 looked really fast.. especially for a x11 motor. If you ever need more help with the esc let me know..
James
Anemic_SluG is offline
Old 06-12-2010, 05:06 PM
  #4563
SpeedySST's Avatar
Default Plug arrangement
Hey guys, I just got the GT 2.1 and there is no instruction as to how to plug in the esc to the receiver or to the LCD program card for that matter. Am I missing something? Just need a diagram/pic of how the plugs are arranged. Thanks~
SpeedySST is offline
Old 06-12-2010, 05:15 PM
  #4564
cannon's Avatar
Trader Rating: 35 (100%+)
If you go to Hobbywings website www.hobbywing.com and go to the download section, most of the manuals are able to be downloaded from there. AS the Hobbywing is the same as the SP you should have no issue
cannon is offline
Old 06-12-2010, 09:13 PM
  #4565
guys need alittle help here just had the new fireware setup with 422 with a 13.5 im running offroad and my problem is pulling wheelies all over my setting are
4-9
9-8
12-7
13-3
14-4
15-3
so what setting do i mess with to get a little less punch i love the top end its flying but if i punch it the front wheels instanly go up and over or maybe start with messing around with the slipper idk what do you guys think?
Old 06-12-2010, 09:19 PM
  #4566
mr crum's Avatar
4-9
9-8
12-7
13-3
14-4
15-3
try #15 at like -6 that will give you less punch if the slipper isnt slipping atleast 2 feet then u might wanna give that a turn to the loose
mr crum is offline
Old 06-12-2010, 09:40 PM
  #4567
SpeedySST's Avatar
Canon, the HW ESC is different of course. The receiver link is attached internally.
Old 06-12-2010, 10:02 PM
  #4568
Super Moderator
charlie_b's Avatar
You can find this info on the Speedpassion.net site.
LCD Wiring Diagram
charlie_b is offline
Old 06-12-2010, 10:29 PM
  #4569
Default 2.1 pro
Hello
can you please tell me how the 2.1 pro compare with tekin and sxx since we have only this two available here?
thank you
Corally_27 is offline
Old 06-13-2010, 12:13 AM
  #4570
Super Moderator
charlie_b's Avatar
Originally Posted by Corally_27
Hello
thank you
WHat i can tell you is out of the three, i felt the 2.1 has the most linear feel. WHen i drove a few Tekin's with Cyclones, there was an initial "lag" if lack of a better word, then the Boost of the Tekin would kick in and have gobs of power. The LRP was smoother than the Tekin, and had decent power mid and top. Both ESC's are very good in my opinion. Even though i am biased towards Speedpassion, i have to honestly admit i like my 2.1 much better. The Linear powerband is a must for me. I like feeling the input of the trigger with out the "lag" the Tekin does. I also like the fact that with Medium settings, it is up to par with both Tekin and LRP. I ran Max boost this weekend in RCGT and i do have to say, hands down i love my 2.1. Very powerful and with the new 52* software, we get no lag or no cogging at all.
It really comes down to preference. A lot of local racers here in Cali love the Boosted feel so the lag isn't an issue. For me, it has to be smooth.
Old 06-13-2010, 01:57 AM
  #4571
defcone's Avatar
Trader Rating: 15 (100%+)
What does it mean when my speedie blinks green non stop, but the motor still runs perfectly? I'm running a GT2.0 Pro with a SP v2 4.0t tried different sensor cables, recalibrating still has the green light flashing.
Thanks in advance.
defcone is offline
Old 06-13-2010, 06:05 AM
  #4572
Oh man, I was so happy, now you’ve went and got me drooling again. What’s the story on this 52* soft/firm/whateverware? Is this something you’re working on yet to be released? When will it be available, Stock/Mod, suggested settings, please please share. Thanks in advance!
Dave H is offline
Old 06-13-2010, 06:08 AM
  #4573
Originally Posted by usernamed
Hi guys,
Tried the 422 software for the first time last week. Im running a LRP X11 on 4 cells on a track with a long straight.
Currently im running:
9 AMTS: value 5 (15 deg)
12 SC boost: 2
13 SC RPM delay: 1 (4000rpm)
14 SC throttle delay: 1
15 SC punch: 2
Im running 75mm rollout and the car is very fast on mid and high rpm's, but lacks a little bit in the bottom end. Gearing shorter doesn't do the trick, it actually looks like the punch decreases.
Any suggestions?
usernamed is offline
Old 06-13-2010, 06:25 AM
  #4574
4-9
9-8
12-7
13-3
14-4
15-3
So what’s the problem? Yep, I’m an offroad lurker here too, Mr. Crum is right of course, try backing off/higher option # on setting 15. Helps reduce motor heat too. My problem with it too jacked up is big nose lift on jumps. Fun problems to have, I'm starting to get the hang of it.
If I may ask, what motor, and what gearing are you using? I’ve tried everything from 6.8 to 8.0 FDR with a Novak 13.5 in a truck. But I’m too busy trying to hang on and laughing to really get a feel for what’s best.
Dave H is offline
Old 06-13-2010, 07:30 AM
  #4575
Super Moderator
charlie_b's Avatar
Most likely it will be released with in the week. It will be STOCK and MOD version of this software. It is very successful on the track where Reinhard and other drivers are loving totally loving it, including me.
