The Speed Passion Thread
#4531
Hi is this
http://www.muchmoreracing.com/store/...oducts_id=3547
the same as the GT2.0? Can it be updated with the 422 stock software the same?
Thank you
Thank you
I run the Muchmore Fleta 3.0 and have had 422 & 518 on it, great speedo and goes like a rocket
Thanks,
Dan
#4532
#4533
Does anyone have a good starting point setup for a Sp V3.0 6.5T for a track like this? : Click! (the main straight is about 100ft/30m long) traction is medium/high
ESC SP GT2.1 (with MOD firmware)
Motor 6.5T sp V3.0
Car TOP Photon
Rubber tyres
Many thanks!
Motor 6.5T sp V3.0
Car TOP Photon
Rubber tyres
Many thanks!
#4534
Hi. I dug up my old car to run rcgt powered by 1.1 lpf. I havent run this car for over 2 years and it seems way slower than i remembered. Compared to another car with 27t brushed powered by same battery, it just doesnt move. It was run on indoor track and never overheated. Could I have messed the motor or the esc by overheating it with soldering iron? I dont know what would have messed it up. I still have another lpf powering a 10.5 and that seems to work properly.
#4535
[QUOTE=Fastfreddy74;7510608]Does anyone have a good starting point setup for a Sp V3.0 6.5T for a track like this? : Click! (the main straight is about 100ft/30m long) traction is medium/high
Motor 6.5T sp V3.0
Car TOP Photon
Rubber tyres
Many thanks! [/QUOTE start with this you may want to go up or down as you go along. 9/4 12/4 13/2 14/1 15/4. fdr start around 8. watch motor temps. 160-170f should be good.
Motor 6.5T sp V3.0
Car TOP Photon
Rubber tyres
#4536
Thank you mr fit, what firmware do you think is best for such motors? I'm currently using 205mod...
P.s.
What about DRRS setting? (item #4)
Forgive me for so many questions
P.s.
#4537
#4538
Keep the 422 firmware. Just tone it down for mod. As this firmware was made for stock. Now you have the options for turbo delay timing and turbo boost. Similar to the tekin. The DRRS setting I usually keep it at 8 or 9 depending on your gearing. But now you can fiddle with option 13 and 15 as this will give you more punch. So you don't really have to worry about the DRRS.
#4542
I'm thinking about IIC, where there's a 17.5 class (no timing) and a 17.5 class (open ESC), and how I'm going to handle running both. Re-flashing the firmware on an ESC between each run seems like a lot of work. Does the little programming box store profiles and things like that? Can you flash with new firmware and load up your settings pretty quickly, or do you have to change your settings each time you load the new firmware?
#4543
Super Moderator
#4545
GT 2.1 on F104Pro with 17.5 motor
Hi,
Just a quick question. Can anybody please share a base setting for 17.5 motor on a F104Pro using GT 2.1 Pro Stock. Thank you very much for sharing. I just purchased a brand new unit and it will be really helpful to start with a safe and good base. Thanks again.
