The Speed Passion Thread
#4336
Super Moderator
Hi guys, I'm set to try the 422 software down my club on Friday with v3 10.5
the track has a 20m straight and i was hoping someone has tried it with success..what are the main settings to play with? I don't want it too punchy on the infield but would like to rip down the short straight
cheers mark
cheers mark
4/8
9/8
12/6
13/3
14/2
15/3
If you are temping higher than 160*F, then lessen your #15 to 15/4. gearing will depend on your driving. With #15, higher parameters =less punch.
Good Luck.
After about 2 minutes, check your temps.
#4338
hai, can i used this firmware V1.05_100420.. to run 3t motor?? or this firmware only for stock motor??
#4339
Super Moderator
09205_MOD-for mod motors
100422_Stock for Stock Motors
100508_Stock Zero for Zero Timing as per Roar Rules.
To answer your question if you use the 09205_Mod software, you can use it with your 3T motor.
Yes, you can use the new firmware.
#4340
The V1.05_100420 has 3 software installed in it.
100422 has added some function. can i used boost n turbocharger with 3t motor
or i just can used 09205 firmware to run my 3t motor, without no turbocharger function..
some confuse hehe,
#4342
#4343
You can always mix and match and try out all the software with all type of motor, however, you must be very knowledgable about speed control, along with motor tunning and the latest Supercharger/turbo feature in order for you to take full advantage of the software.
You can give the 422 a try by turning the item #12 off and see there are any different to the 205g without the supercharger.
#4345
I have not tried anything faster then 10.5 with 422 software, but if I am going to try it, I would do at least 1 setting lower from the 10.5 setup.
Speed Passion drivers from Europe has been testing the 422 software with 3.5-4T motor, however, we have yet to receive any recommanded setting for these motor use.
See Charlie-B 10.5 setup above and decrease a notch on 9, 12-15 items (don't forget to gear lower then 10.5)and temp motor every 5 laps or so.
Let us know your testing....good luck.
#4346
YES....you can use 9.5T motor with 422 software. HOWEVER, you must turn down the #9, #12 to #15 features in order to keep the 9.5T motor by blowing up.
#4347
Neutral range is the amount of "play" in the trigger. So the larger the number the more you have to pull the trigger to get the car to go forward or operate the brakes. It doesn't change the cars performance as much as the performance of your radio as a interface to the car. Check out the included picture for clarification.
-j
-j
cheers
Ali
