Roll Centre and Camber Gain Calculator
#77
Bob,
For whatever reason my browser cannot find the webpage link. I tried one of your earlier links and the browser was able to connect but I guess that you have removed the previous file versions. Might want to check out the problem.
#78
That's strange. I just tried the link and it went straight to it no problem. The link does work because lots of people have downloaded it.
Try this link and if it doesn't work I can email it to you.
http://www.mediafire.com/file/4m4tgm...CentreV162.zip
#79
BobW, just measuring some of the other cars I have onthe shelf... (XXX-S, JRX-S, TB-03). I'll email you the files when I am done. It will be quite a while as I am only doing it when I have some spare time.
The new version is much better. I do like the animations... cool. Was thinking if there can be any animations for vertical chassis movements? The setup page is much better and so is the tyre/dia/camber inputs are a lot more convenient!
Keep up the good work!!
#80
Bob,
Thanks for the reply. Did some checking based on your reply. As it happens I use AVG anti virus software which has a plug in to my browsers and for whatever reason it was keeping me from going to the link. Once I disabled the protection I was able to go to the link that you posted. This was the case for both IE Explorer and Mozilla Firefox. I don't know if your hosting site puts out something that triggers the AV stuff or what. Quite frankly I hate AV software as it seems to take over my computer and I seem to be clueless in stopping it. I was finally able to download the software.
#81
Calvin. Glad to here you got it to work. It's to bad we have to use AV software but unfortunately that's the world we live in. At some point I will get my own site so I don't have to rely on someone else to host the files.
JRXS-R. Send the models through when you have them. Thanks for sharing.
#83
BkSpeedo
Thanks I'll look for your email.
The Save and Load Setup is only intended to save values on the setup page. It is a separate text file to the model data base. The idea being you can play with your setup values, save it to a separate file, do some track testing and then come back to values without having to re-enter everythng, tweak them again and so on.
To save changes to the model use the save feature on the Model Page. That will change the values in the database on which all the calculations are based.
#85
If you can find the RCCar.sdf file you can just email it to me. It will be located under.
C:\Documents and Settings\"Your User Name Here"\Local Settings\Apps\2.0\Data\0K83OYYR.RWE\GO9EDKOX.0WO\r cro..tion_a38eaf8c0fd7bcd7_0001.0000_d82596badafa4 2e7\Data
Or something of that format. Just keep drilling down until you find the file. If that doesn't work the Alt-PrntScrn method works. Just keep pasteing the screens into a word or pdf document. I posted the procedure and a sample .doc and .pdf file on page 3 of this thread.
#86
Program
For some reason i can't get this program to work on my PC.iam running vista 64,but i turned off a bunch of services,anything special that needs to be running for this to work?
Also has anyone measured up a TRF 415 MSX MRE?
My buddy was ready to toss his Type-R In the garbage until he discovered this program,now he's the next Matt Francis!
#87
bob i havnt had much time to play with the version you sent me but when i opened it up it all looked really cool. i will let u know what i find.
#90
Well the new version has been out for a couple months now and this thread has been very quite. That can only mean the program is working flawlessly and meets evryones needs. Yeh right.
I'm sure someone has found some bugs, has suggestions or would just like to provide some feedback. Anything would be appreciated.
