Engine tuning 101
Engine tuning 101
I have two MR 12 3port motors. One runs super the other just the opposite. I know that my setting are on the rich side but the motor still runs very hot 256* to 285* and this is with the body off. I need some neede tuning advice... Thanks!
is sounds like you might have an air leak
Air leak huh, okay seal the carb back plate fuel fittings, do I also seal the head somehow? Is there anything else or some tricks to getting it right? thanks...
Registered User
Don't seal the head!!!
Sealing the Carb and the back plate should eliminate any air leaks if you have them.
Did you break these two engines in the same way? And with the same fuel?
There are many more variables you left out:
What kind of car are the motors in?
Are the cooling fins with the cut through the center getting air flow through it?
Is your two speed shifting? Do you have a two speed?
What plug are you running with what fuel?
Where are you located? (high altitude, low altitude?)
Let people know more about your settings and they should be able to assist you in a more precise answer.
ok, here goes:
Car: V-One RR Evolution
Fuel: Mugen Seiki 20%
Glow Plug: O'donnell 77
Exhaust: RD Logics 1 piece outlaw pipe
Current needle settings: high speed needle 4 3/4 out
low speed needle 3 3/4 out
midrange stock settting (did not adjust)
Characteristics: starts ok with good priming, at full throttle speed is fairly good, transmission is shifting, at idle engine loads up in a very short period and engine dies out, at low speed throttle is very rich sputters alot, temp ranges at this setting from 207*at idle to 285+ after running for at speed for less than 3 minutes. Need more info? I can't figure it out... Any advice will be greatly appreciated. Thanks!
Originally posted by Naluboy
ok, here goes:
ok, here goes:
Deffinatly rich on the low side and lean on the high
If the low end is rich the motor will idle ok and there will be a large volume of mixture in the crank. This takes time to clear into the cylinder, about 2-3 secs so as you apply the gas the mixture in the cylinder will get leaner and leaner.
To adjust your low end let the car sit at idle and apply full gas for 2 secs and release. If the engine returns to fast idle then drops to slow idle the low end is to rich.
Lean out the bottom end then try again until the engine returns to fast idle and stays there. Adjust the idle screw to reduce the idle revs down.
You now need to richen up the top end. Open 1/4 turn and try again
Another cause of overheating is to low a compression ratio. check the head clearance.
Cheers
Cheers
Hey all thanks alot for all the advice. I'll definitely try those suggestions. So far I sealed the carb and the back plate tried running it but still only so so results. It doesn't run those high temps anymore but definitely need to be fine tuned. Once again thanks for your responses. As we say in Hawaii~ MAHALO(THANK YOU)!!!
