Schumacher Mi4
#3108
So, I'll know hopefully by this weekend if it fits an LP on its own. I'll also know how much weight it adds.
-Mike
#3109
Problem with steering
@all
I have problems with steering trim after hitting something.
Don't get me wrong, i'm an experienced driver, but sometimes you get hit or you touch something if you want to push hard. If this happens, the car pulls to one side and i have to trim new (maybe 3 steps/beeps) i hope you understand. If you have to trim during a main, your race is gone.
I have a CX with standard steering (not twin-point) and i use no servo saver. I have changed the whole steering yet and also the servo, still the same issues. Has anybody else experienced similar problems? Would the twin-point steering maybe help?
I never had this with other cars (T3, TC5)
Thanks in advance.
Thanks in advance.
#3110
@all
Thanks in advance.
Thanks in advance.
If it doesnt feel smooth, the neutral point in the servo will wander and hence thats why the car will not track straight.
#3111
@all
Thanks in advance.
Thanks in advance.
1: The car is badly tweaked during the collision. (check the car for tweak after every run and make sure all screws etc are tight).
2: The plastic servo horn has slipped round on the splines of the servo. (servo saver advisable if your prone to accidents).
3: The servo itself is moving between the mounts. (alloy mounts cure this).
4: The servo is not great quality. (cheap servos are renouned for drifting around the neutral point).
Hope this helps.
Mark
#3113
Biggest issues i've had with servo and straight line tracking constantly changing has been;
Tightness in the steering system, ball-joints, knuckle pins stiff ect.
Kit servo saver spring rubbing on servo. 0.5mm shim between saver and servo spline helps.
Plastic servo mounts. Please ditch these first chance you get as they are always the problem.
Servo too tight against the chassis. When mounting the servo on mounts always slide a bit of thin cardboard underneath, between the servo and chassis then tighten the mount. When you pull out the card you get a small gap that should stop chassis tweak caused by the servo pinching the chassis in a knock.
#3114
@all
Thanks in advance.
Thanks in advance.
#3115
nice alloy pulley
fyi i installed the new center alloy pulley (tried 3 plastic pulleys prior) last night-and i noticed its better aligned with my gear diff.....the rear belt doesnt wander to one side of the diff pulley's wall on wheel rotation
#3117
I would say either use servo tape, goo or metal mounts but not both. Servo mounts, or servo lugs will move and flex in a bash, then spring back but with tape they wont. Like wise tape will flex about but the two together seem to shift and hold.
#3118
New section added to my website
Upgrades fitted to my Mi4cx
Including the New Long Top Deck
You can find it in the photos section
http://www.car69.me.uk/upgrades-fitted-to-my-mi4cx.html
If the link does not work goto www.car69.me.uk
HTH Someone out there
#3119
-Mike
#3120
SPUR GEARS
Will standard robinson racing machined type spur gears fit the MI4LP?
