Schumacher Mi4
#2192
I'm after directions on a Mi4-LP set-up for MuchMore Absolute V 36's on asphalt painted with an abrasive high grip surface repair substance. I have started with Chris Grainger TITC set-up and find it very taily through tighter corners. BUT the bigger problem is the tyre wear, one run.
I have a local supported driver going to give me direction and help. But would like to collect as much information to help me learn.
You can put more shims in camber links, 2 mm front underbraket, and 0 rear.
HPI soft srpings, blue - silver, with good oil 45-50 real WT.
And 1 mm longer rear, 3 mm front rear arms, cure the rear problem.
The new steering, is smooth, for me best from the old one, but i see in the new car, go with the old, and more UK drivers too, i like the new steering but the setup need a litle mods.
Greetings, Luis C.
#2199
Just read the review for Mi4LP from couple months old RC car action, is street price really $480?
Medium flex compound a-arms... interesting
#2200
There's a lot of them around used for $300 or less with spares, though.
What are you referring to about the a-arms? The Mi4LP comes with CF ones.
-Mike
#2203
tamale - countersunk and black anodized. however, not cheap. they would come with tool steel hingepins as well due to the nature of the design.
