Losi Speed T shocks to XXXT CR shocks
Ok well I have a set of four speed t shocks from a car I parted out before. I kept the shocks, radio, and brushless setup for another car.
I have one pair of speed t shocks on the front of my other car, but need to know what to change to get the other pair to the length of the rear XXXT-CR shocks.
I think the threaded body is already the same length as the rear XXXT shocks, are the shafts the only thing that needs to be changed?
Thanks guys
Thanks guys
I did a quick look on the parts explosions for you. The XXXTCR uses a 1.2" rear shock shaft. The Speed T comes with 1.0" shock shafts. I don't know if the bodies are different as they don't put the size on the Speed T shock bodies in the parts explosion. You may need to find a XXXT to hold them up against.
I couldnt find out of the size of the Speed-T shock bodies.
