brushless system and lipo recomendation for rustler
The CC has way more adjustments and is relatively cheap
But for a rustler I wouldn't go higher than a 4600KV due to it's already fast gearing in the transmission.
Yes, the Sidewinder has a low voltage cutoff - one you can set with the castle link.
Diff between Mamba Max and the Sidewinder is the amps they can handle - the MM can handle more amps than Sidewinder, reason it costs more. Unless you're going to use teh MM in a 1/10 as well, Sidewinder would be a better choice.
