BEST PIPE FOR A O.S. SPEED 08/09 EDITION
HI
I GET A O.S. Speed .21 VZ-B V-Spec II 08/09 Worlds Edition an I want to know what is the best pipe choice, Carolinas rc recommended:
jammin JP-3 and O.S. 2060.
The price difference between this pipes translete to performace difference?
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
HUH? The 2050 on that motor is a DOG. JP-4. (on the other hand, the 2050 is good on a regular V-SPEC... and so is the JP-4)
Also the 053 pipes are really good on a regular V-SPEC (slightly better than the JP4 actually, I've seen the dyno tests to prove it) but not sure on the speed.
i run a 2041 and get great mileage
I've had great results with a speed and a stocker using the 2050 with a smooth flow header and a 5.5mm restrictor, 11mins plus on a tank(losi2.0) with great bottom and good top end
AE 2035 is good on about anything at a great price.
2060 was made for that motor.
JP-3 good power band but not as good mileage.
I ran the JP-3 for a gallon and it did pretty good, did not get the fuel mileage that the 2060 does. IMO the 2060 performs better and gives you great mileage.
Like everybody else says; go with the 2060.
I like the 2050 overall better, i found tho if you are running on a larger track with smaller jumps and you dont need that low end snap, try running the 2060 U manifold to get a bit smoother power range... but most tracks i run the original 2050 setup with the original manifold
