Help with Hyp 1210i a123 mode selection.??
when i scoll thru modes all it has is nicad nimh lipo and pb...
it says a123 supported on the box but how do i set the charger...???
manual is no help....
2 First hit enter and select correct maH and # of Cells
3-Hit Enter, Increase, Increase, Increase till you get to Lipo, then hit enter, hit increase and it should have Life, hit enter, then decrease till you get to LiFe "Charge" Way more simple than I make it sound.
I use the same exact charger, if you need drawing on how to connect the balancer for a 3S LiFe, I can show you it.
1-Turn charger on.
hmmm. still cant find it... Not totally sure if it is a123 supported.... is there a way to tell...???
Does a battery have to be connected to find life mode...???
